What is the difference between a 8BA and a 8RT flathead V8
I have a 8RT that has just been rebuilt in a 1952 Ford F1 and found that the block is cracked at the top of the valley, behind # 1 valve springs level with the valve guides. I didn't discover the crack until I put water in the radiator in preparation to crank it and noticed water in the oil.
I guess I will have to find another block.
Can anyone tell me what blocks will work with my 8RT? A 8BA looks the same but I am not sure. What are the years I can use and what are the differences?
Any flat V8 from '48 to '53 will work, but you want to stick with engines that use the wide belts. Car engines after (I believe) '51 used narrow belts. You can use the block from a Car engine, just swap the pulley and water pumps from your old engine.
One caveat; Cars in '48 still used the older style V8, you don't want that. Trucks got the newer 8BA-style engines first (in '48), then in '49 all used the newer style engine.
Pulleys, water pumps, and fans/generators can generally be swapped to address the belt issue(s).
kens65fb
06-17-2017 12:09 AM
farmall_7
15
05-08-2016 06:12 PM
Flaflathead
02-13-2004 08:34 PM
Kurts50
Flathead V8 & Flathead 6
06-10-2002 08:13 PM
