Need help picking engine
Old 02-04-2018, 09:00 AM
Kolby Haynes's Avatar
Kolby Haynes
Kolby Haynes is offline
Alright so I have a1991 F150 2wd 3inch lowered with a monster trans currently on the way. Now my goal horse power isn't anything crazy I'm just wanting about 350-400rwhp but it seems a little far fetched with my 5.0 that's currently in it. Anyone have suggestions on a good engine that'll get to that goal without costing too much. Thanks!
Old 02-04-2018, 09:34 AM
Briansshop's Avatar
Briansshop
Briansshop is offline
A 351w with some form of boost, or a 460 swap would do. You could get that power from a NA 5.0 or 351w but it'd be a pain on the street - big cam,high RPM,...
Old 02-04-2018, 09:39 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
NotEnoughTrucks2014 is offline
If that transmission you have coming is for your 5.0, you are limited to what fits. 460 uses a different bellhousing pattern and that means a different transmission. 351W does seem to be your best choice. Make sure you use the correct flexplate.
Old 02-04-2018, 09:43 AM
Briansshop's Avatar
Briansshop
^ Right on ^,I wasn't thinking about the trans!
Old 02-04-2018, 12:25 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
427 stroker kit in a 351 !! 400 hp to the rear wheels is a lot considering your stock 302 with a C6 is laying down less than half that.
Old 02-04-2018, 12:26 PM
Mudsport96's Avatar
Mudsport96
Mudsport96 is offline
Originally Posted by Kolby Haynes
. Now my goal horse power isn't anything crazy I'm just wanting about 350-400rwhp .... Anyone have suggestions on a good engine that'll get to that goal without costing too much. Thanks!
What is your budget? Is more important than what do you want the truck to do
Old 02-04-2018, 10:48 PM
Kolby Haynes
Budget? Honestly could do 3k and as the truck it's a DD/street
Old 02-05-2018, 08:04 AM
Briansshop's Avatar
Briansshop
3K isn't going to get you there.
Old 02-05-2018, 09:56 AM
Mudsport96's Avatar
Mudsport96
Ok, 3k... so what do you want/need 350 hp for? Just to play around or you trying to race? And what auto trans do you have, the e40d or a 4R70w ?
Old 02-05-2018, 01:18 PM
Kolby Haynes
Both! I have a built AOD by monster trans
Old 02-05-2018, 01:43 PM
NotEnoughTrucks2014
That is neither a 4R70W or an E4OD.
Old 02-05-2018, 04:12 PM
Kolby Haynes
​​​​​​​Well I obviously wasn't talking about those trans... You asked if I wanted to race it or just mess around. That's what I replied "both" to...
Old 02-05-2018, 05:37 PM
Conanski's Avatar
Conanski
Conanski is offline
400 crank HP isn't far fetched for the 5.0 and you might just do it for under $3k with some savvy shopping, but you will be giving up EFI and going to a carb. 500 crank HP will translate into a bit over 400hp to the ground but now you're getting into the area where the stock 5.0 block is a grenade waiting for a place to go off, so you can make it work but it's anybody's guess how long it will last. If you want a motor that you can just keep adding to safely start with a 351.
Old 02-05-2018, 05:44 PM
Robert Long's Avatar
Robert Long
Robert Long is offline
I have read that you can get adaptors to convert aod or c6 to a 460, might do some research in that direction.
Old 02-05-2018, 06:51 PM
Mudsport96's Avatar
Mudsport96
You could start with your stock 5.0 and GO to a 5.8 later for better power and reliability. But, for 3 grand you are limited so boost is the best answer.
and keep in mind this is a bone stock mustang 5.0 so other than the HO cam and forged pistons it's just a stock 5.0.
if you stayed at 6 to 7 psi you would be ok I think. Then build a street 5.8 and boost it. 400 easy hp and freight train tq.
Quick Reply: Need help picking engine
