335 engine machine shop question
Old 02-02-2018, 07:47 PM
RustyTrustyF150's Avatar
RustyTrustyF150
RustyTrustyF150 is offline
My Cleveland engine block came out of the soak tank and revealed its problems . The worst problem being where the cylinder head bolts thread into the deck's bolt hole threads . Awfully bad after setting with no bolts screwed into them .
Any one else encountered this ? Could a shop drill and tap threads into the water jackets and use sealer on the head stud bolts if a person could go this route ? Don't think there is enough meat left for a heli coil to hold onto .
After googling inserts there might yet be hope , Inserts start out light duty and can work up to some heavy duty threaded bushing type .
Old 02-03-2018, 04:45 AM
Crop Duster's Avatar
Crop Duster
Crop Duster is offline
It might be cheaper and better to get another block. Try (Car-Part.com) and set the search for distance. Remember those engines were in Mustangs, Torino's and big Ford cars. There are still plenty of 2 bolt blocks out there. Also sometimes they turn up on Craigslist.
Old 02-03-2018, 12:04 PM
RustyTrustyF150
if the machinist at the repair shop shakes his head at the idea of repair inserts in the deck I will probably give way to defeat . Its the idea of all those threads holding combustion pressure .
But if new threads could be cut for a threaded bushing and it works ,,,,, just never went down this road .
Old 02-13-2018, 06:04 PM
mark a.'s Avatar
mark a.
mark a. is offline
There is nothing wrong with Helicoiling head bolt holes, I've done it before. One thing though, do it on a mill to keep it straight.
Old 02-13-2018, 06:18 PM
RustyTrustyF150
A heli coil is fine if the threads are in condition yet with no rust or maybe just pulled out of condition , mine are worse . Probably the threaded bushing repair job needed .
Old 02-14-2018, 09:23 AM
mustang81's Avatar
mustang81
mustang81 is offline
A heli coil is stronger than the original. The hole is bigger than the original and stonger when it's properly done.
Old 02-14-2018, 11:10 AM
RustyTrustyF150
Quite right .
Old 02-17-2018, 08:57 PM
Filthy Beast's Avatar
Filthy Beast
Filthy Beast is offline
Are they ALL bad?
Either way you go, you'll have to clean and chase the threads first. THEN do your head scratchin'.
If your favorite shop says, "Uhh...don't think so.....", time for another shop.
You could go with ARP studs instead of bolts......
Old 02-18-2018, 03:36 AM
Crop Duster
Cylinders
Are you sure the cylinders will clean up at say .030. I've never ran across a block with corrosion as bad as you say it is and have the cylinders not be just as bad. If you have to have even one of the cylinders sleeved plus 20 heli-coils you will have way more invested in that block than it's worth. Not to mention having it decked and bored.
Old 02-18-2018, 01:09 PM
RustyTrustyF150
no repair started yet . waiting for a estimate .
Per4mance
10-25-2016 11:48 PM
john fin
06-20-2008 05:19 PM
46yblock
07-19-2007 11:28 AM
palmercomputes
12-09-2006 06:07 PM
Pustman
08-11-2006 12:44 PM
Quick Reply: 335 engine machine shop question
