1978 - 1996 Big Bronco
Fuel Tank Part # Help
Old 02-02-2018, 06:51 PM
kennyfzj80's Avatar
kennyfzj80
kennyfzj80 is offline
So I have a 1996 E150 van with a drop floor conversion.
They get rid of the dual tank set-up and just put a large one in the back. I think they use a bronco tank.
I've searched for the part number on the side but I'm failing horribly at finding anything.
I need it to order the fuel pump, I want the exact same fit. Also per the records given to me by the PO, the pump has been replaced at least once so I'm not sure the pump that is in there is the proper one.
TIA for any input.
Old 02-02-2018, 08:01 PM
Black Ford XLT's Avatar
Black Ford XLT
Black Ford XLT is offline
https://www.oemfordpart.com/
Genuine OE Factory Original Item
Old 02-02-2018, 08:08 PM
Black Ford XLT
Old 02-02-2018, 08:11 PM
Black Ford XLT
Old 02-02-2018, 08:28 PM
Black Ford XLT
https://www.oemfordpart.com/ To be sure Please search here listing truck year engine etc Good luck TR
Old 02-03-2018, 01:22 PM
kennyfzj80's Avatar
kennyfzj80
Thanks but I can't find that part number anywhere on the site.
Old 02-03-2018, 01:26 PM
Black Ford XLT
Kenny, Number Dummy is good at tracking Ford part numbers, try him. I do not believe that is a Bronco tank .How many gallons?
TR
Old 02-05-2018, 12:27 AM
McLeod's Avatar
McLeod
McLeod is offline
It doesn't look like a full size Bronco tank to me either.
There is also a tag with a number in your picture.
What does that white sticker up near the frame say?
Old 02-06-2018, 12:00 AM
kennyfzj80's Avatar
kennyfzj80
TR
I think it is a 32-33 gallon.
Old 02-06-2018, 12:03 AM
kennyfzj80's Avatar
kennyfzj80
yeah that tag literally vaporizes when I touch it.
What I can make out on top
......D(or O) GROUP
.....porated (probably incorporated).
lake forest, IL
Old 02-06-2018, 09:53 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Ford prefix F2JL indicates the part was designed in 1992 (F2). J=Industrial / Marine engines. and the L=Industrial Engine Parts & Service.
You will never find it at the automotive parts houses IMHO.
Old 02-06-2018, 11:32 AM
kennyfzj80's Avatar
kennyfzj80
Thanks so much!.
So would I just have to find any fuel pump that is meant for a 5.8L and hope that it fits?
Old 02-06-2018, 11:45 AM
McLeod's Avatar
McLeod
McLeod is offline
If you don't need the van everyday, why don't you drop the tank and remove the pump.?
Then you will have a better idea of what you will need.
If the PO records show a replacement pump at some point, is there any record of what he put in it?
Unless you are dealing with high milage, going into a third fuel pump seems odd.
My original OEM pumps in all of my Fords get at least 175k miles out of them and several have gotten well in excess of 225k miles.
Old 02-06-2018, 12:44 PM
kennyfzj80's Avatar
kennyfzj80
If the previous shop put the wrong pump in there, can it cause lean conditions?
kennyfzj80
03-26-2024 06:06 PM
Fran D'Aloia
05-06-2018 11:55 PM
reed1951
24
09-23-2013 02:57 PM
ChristopherN
17
11-16-2011 07:47 AM
F250351W
05-20-2010 03:02 PM
Quick Reply: Fuel Tank Part # Help
