Is the 5.0 coyote rebuildable?
Prior to 2018, the engines used steel sleeves, so you can in theory replace them if they had severe wear. Starting in 2018, Ford used the plasma spray bore that deposited a thin coat of hardened steel onto the aluminum cylinder wall. This slightly increased the displacement (because there is no longer a steel liner). If you wore that out, you could in theory still replace it with a sleeve, bringing the displacement down slightly (back to that of the pre-2018 models).
Dean88
02-19-2009 09:25 PM
MustangGT221
12-21-2004 10:44 PM
