Brake booster not available?
The brake pedal has a Ford ID number stamped on it, post what it is. The number will be similar to this: D3TA-AA or D3TA-2455-AA
The booster must match the brake pedal, so once the number is posted, mikeo0o0o0 or I can give you the info.
I snapped a picture of the only number on the pedal. It doesn't seem to match the format.
I bought it more or less as is so the miss match has always been an issue for me. My son has a 75 that was my father's so I know the background of it, and the booster on it looks the same. It had the 44HD with drums in front.
Here's the picture.
Here's the picture.
This particular pedal fits:
73-77 F100 w 2WD w/o power brakes F100/150 4WD
73-74 F250 6200 GVW std. brakes, 6200 GVW w/ heavy duty brakes
75-76 F250 w/ 6200 GVW w/ std. brakes w/o speed control, 6200 GVW w HD brakes w/o speed control
73-76 F250 6900, 7500, 8100 GVW w/o speed control, F250 4WD
73-76 F350 w/o speed control
Taking a guess, 76 F250 4WD w/ HD dual piston disc brakes takes booster P/N D6TZ-2005-H, this booster is 8.80" in diameter. See if you can find the ID number D5UA-2005-AEA stamped on the housing.
I did a search and couldn't find anyone with a NOS unit.
This thread may interest you, I believe ultraranger used a later F-150 setup
https://www.ford-trucks.com/forums/1...ing-valve.html
Been reading all the reports and knew that I needed a booster soon, started checking. Figured I would get the same answer as all of you, but had to try.
Yep, my local go-to shop just sends them to the local rebuilder that I was going to send my old one to after I got the new one. Looks like I'll be sending it out sooner rather than later.
Or I may bite the bullet and just go hydroboost after all. I'm not necessarily into changing things that don't need it, and while the Early Bronco boosters SUCK(!) my F350 always had tons of assist with the vacuum. So adding more plumbing (and cost) was not high on my list.
But now that might all change. All that whining coming from somebody who's shop actually makes a kit! https://www.wildhorses4x4.com/produc...ke_Kits_7879yr
It's clean and should give good boost. Especially if I upgrade to a Saginaw/Delphi pump like I'm contemplating now too. Geez, and here I thought I was going to save money and keep all my old stuff.
So yeah, that was a bit of a shameless plug, but now with such a poor supply of vacuum boosters, going hydro might not be out of line. Especially with the F100/150 trucks which some convert to the F350 booster anyway.
Paul
Paul
