My 78 F150 Custom 4x4 SWB
#106
#107
#109
#110
Steering is likely original, and does not have an adjustable draglink. It’s far cheaper & stronger to build my own steering out of GM “1-ton” tierods found on 3/4-1 ton trucks using 1.5”x.250” wall DOM. With my dealer prices I can do my own for under $180.
#111
#112
I
#114
#115
Finally made time to start cleanup in my shop & scrubbed down the 460 block so I could start assembly. Had a couple casualties as in my finger between engine stand handle & side brace. Then walked backwards into my crank & let my leg stop the fall! Just another day in the shop!
i started checking ring gaps today. Cylinders were originally about .0015 out from .030, they ranged from .0285 to .0290. Checked #1 & 2 take out rings & they measured .035-.040 when should be .016.
the new Clevite moly coated rings measured .016 on Cyl 1-4, will check the rest tomorrow & get the pistons in.
#117
#119
#120
Well, looks like my ankle didn’t break the fall... my crank must have hit my transmission jack on #1 rod journal...
I’m not sure it’s worth having it welded & reground. Mains were already .030 under & rods .020...
also realized last shop to rebuild scattered the rods from their original location as per stamping on each rod & cap...
so for now, I’m going to sit back, sip my Scotch & debate stroking it out to 545...
