My 78 F150 Custom 4x4 SWB
#76
Just dropped my block off at Local Performance/Machine Shop. Plan is to check each cylinder to make sure there isn't any excessive wear (shouldn't be after a rebuild that was barely run, but I don't trust other peoples work...), Check the align bore of the crank, Vat the block to remove scale/rust etc... from the water passages, and the 3 small places at the bottom of Cylinders 1-3. Any minor rust not removed from cylinders after the Vat, then they'll all get a quick hone-job done. Once I start assembly and get my cam, I'll be taking them my duraspark distributor and cam specs, and will have it recurved to match the specs of my cam. Should have it back in a week or so. as they stay busy with work.
#78
#79
Well, touched base w/ the machine shop today to confirm what the plans were for the 460 block. So they'll be checking over it. hope to hear back status in a day or two. Comp Hi-Energy pushrods arrived yesterday, Cam Kit and Timing Set are scheduled for delivery tomorrow, Oil Pump will be here Thurs. still need to order gasket kit, waterpump, and electric choke kit for my Holley 750.
Once I get the block back, I'll start the assembly, hoping to use it as a teaching moment for my oldest son (almost 10yo), who wants to get into Mechanics as a trade when he's older.
#80
#81
No, because as of now they're not touching the bores, unless something is found wrong with them. Really just checking over whoever did the last rebuild (which appears to only have been ran for break-in) machine work.
#82
#83
They’re aware it’s .030 over with standard rebuilder pistons. If they need more info they’ll call and ask... the shop has been in business with a racing pedigree for the last 45 years, even working with manufacturers to improve designs. I’m quite confident if they need anything, they’ll ask
#84
#85
on
Keep up the good work skyhawc - more pics whenever they're available?
#86
Lol don't be so negative dude. This build is awesome and I'm happy to see skyhawc is taking the initiative to do the rebuild on his own. I didn't do the same, but I wish I had the time/patience to do what he's doing.
as for negativity, it’s par for the course on any web forum... so i disregard it.
#87
Negative?
Here I thought it might be helpful for you to follow up with the machine shop to ask them how they are confirming the bore is correct. It's in YOUR best interest (not mine) to make sure they are doing a good job.
Cast pistons?
skirt coating?
Hypereutectic?
Forged 2618?
They all may call for a different final bore and skirt to wall clearance as well as the OD itself.
How can they check the previous shop's work when the basis is not known?
LIke I said before....I hope it works out for you! (<-- not sure how that is negative)
Cast pistons?
skirt coating?
Hypereutectic?
Forged 2618?
#88
on
All I'm saying is he's got a mother already lol. Not trying to pick a fight. Just trying to point out the obvious - he's got er handled
I think we're all on his thread for the same reason - for sitting back and enjoying another dentside get back on the road.
In any case, keep up the good work Skyhawc. Any pics of your previous builds you can share?
#89
1984 Jeep CJ7, Entire drivetrain rebuilt (minus bottom end of motor) Low mile, original paint/upholstery. Spring over Axle conversion, 2.5” stretched wheelbase at front axle, Full cross-over high steer utilizing original Jeep dana 30 axle. Custom fabricated front bumper (in progress)
1962 Galaxie, ground up rebuild, 4wheel dosc brakes, 3.50 limited slip, mild built C6 with TCI converter & valvebody, mild 390 with 428CJ sized valves, cast 406 shorty headers & more... Converted to XL package with buckets & console. In final assembly at this moment
My 56 Victoria awaiting paint & final assembly - ground up rebuild
1977 CJ7, Bought “built” already, had to do alot of rebuilding due to dangerous welds, inadequate materials... Sold to a friend & further helped him transform into this. Has 55” of articulation on leaf springs
1969 Fairlane, rebuilt entire drivetrain, however rusting from inside out & due to the 390 started to rip car apart
1993 Cherokee full drivetrain rebuild, including Ford 8.8 rear axle swap, more to come in future on this... won people’s best at a large annual show. with my 84 CJ7 beside it.
ZJ Grand Cherokee, I assisted in build setup for an Overland trip. Couple & their 4 dogs travelling from Roanoke VA to Alaska then to Argentina & everywhere in between.
#90
