1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2003 F350 Door Ajar Light
Old 01-30-2018, 08:30 AM
Bartman1959's Avatar
Bartman1959
Bartman1959 is offline
Question 2003 F350 Door Ajar Light
On my 2003 F350 my "Door Ajar" light stays on quite often. I go around and check all 4 doors, and they are all properly secured. Is it a contact that is going bad? What and how do I check this?
Old 01-30-2018, 10:48 AM
DND58's Avatar
DND58
DND58 is offline
Pretty common problem.
With a door open, spray the latch down with WD-40 or something like. Then open/close the door several times. This usually solves the problem. If not move to next door.
Old 01-30-2018, 11:23 AM
rprice's Avatar
rprice
rprice is offline
I had the same problem several years ago on my 2003 F250SD. Turned out to be the driver's side door ajar switch. Motorcraft p/n FOSW-5854 (Ford XF2Z-14018-AD). It is a small switch located inside the door on the latch assembly.
Ron
Old 01-30-2018, 11:48 AM
Bartman1959
Ron
Thanks Ron, I'll check it out, and try some WD40 like Dean said.
Old 01-30-2018, 11:49 AM
Bartman1959
Thanks Dean, I'll give it a try.
Old 03-13-2018, 02:10 PM
02f350blanchard's Avatar
02f350blanchard
02f350blanchard is offline
Angry door ajar problem
I sprayed mine down with WD40 and pull the switch out and cleaned it, but still door ajar light on and chime dinging. Radio also stays on for 10 minutes before shutting off. Cab lights don't light up until after running pickup and shutting key of then open door and they come on. Could this all be because of the door ajar sensor switch on driver door? My truck is a f350 super duty.
Last edited by 02f350blanchard; 03-13-2018 at 02:11 PM. Reason: forgot type of pickup
Old 03-13-2018, 05:27 PM
rprice's Avatar
rprice
rprice is offline
02f350blanchard,
The radio staying on for 10 minutes sounds normal to me, but the door ajar light, chime and cab light operation all sound like what I had when my door ajar switch needed replacement. The cab light times out after about 30 seconds because the vehicle thinks the door is still open, even though you physically closed it. I replaced the switch on the driver side door and all was good; did not worry about the passenger side since the driver side door usually gets 10 times more use.
Ron
Old 03-22-2018, 02:29 PM
02f350blanchard
Angry Door ajar problem
I've tried all the fixes suggested and still no change. That's including spending $47 on a brand new door ajar switch/sensor. Nothing I do works. I cannot lock or unlock with my remote keyless entry. So I use the driver side door lock button and all four doors lock, but then the driver door unlocks. I have to manually push it down to get it to stay locked. By deduction, it seems as if it's a security system problem, but I don't know where to look for the solution.
Old 03-27-2018, 09:56 AM
Bartman1959
Thumbs up
[QUOTE=DND58;17763113]Pretty common problem.Sorry I didn't reply sooner, but the WD-40 did the trick. Thanks.
nousername
Electrical Systems/Wiring
03-07-2008 09:27 AM
bartender
04-08-2006 08:00 AM
JTATMAN
09-11-2005 09:54 AM
baredog26
02-26-2005 07:41 AM
fordnut66
05-15-2004 03:55 AM
Quick Reply: 2003 F350 Door Ajar Light
