Grant Steering Wheel - Removal of Wheel Mounted Cruise Control?
Hi,
I'm looking to add an aftermarket Grant steering wheel onto my '85 Bullnose and was wondering what I need to do with the wiring for the cruise control.
I don't really care to use the cruise control, so I was wondering what can be done with the wiring or if anyone has had (and solved) this issue before?
Thanks.
Thanks.
Yes, the ones that are drive by wire with a servo for the throttle do not need anything but the steering wheel with the buttons, and then some programming to activate the cruise feature.
Not been able to get the cruise to work on my 84 F 150. When I bought the truck, everything for the CC was in place under the hood, but had a standard horn pad. I bought a CC horn pad, no work. Switched the connectors at the bottom of the column, as someone suggested. No work. Found a tilt column, with cruise, at the boneyard, figured I had the cat by the derriere'. Installed said column, no work. Running low on thoughts.....
Sorry cant help but here is a BTTT (bump to the top)
Dave ----
On my truck it is mounted with the computer, which is above the gas peddle.
Is your truck a DS2 IGN system (pre computer)?
Not really sure on your truck.
EDIT: PS The other black box in the photo is the "brain box" for the cruise, you do have this also...........
