2017 6.2 random long crank when starting
2017 with 26k miles on the truck, I have noticed sometimes in the morning and at lunch it takes an extra second or two to crank before the truck starts. Last week I go to start it after it sat all day and it cranked for a few seconds, fired up and shut right off and put up a check engine light. I turned the key off and tried it again and it fired right up. Check engine light went off the next morning. I took it to the dealer this morning and they can see where it threw a code for not starting but that is all they can see and it starts fine for them all day.
What if anything should I do about this? I have 10k left under full warranty and dealer says just see if its gets worse. Its not a huge deal and may only have a extra second cranking twice a week or so but I just don't like hearing it crank so long (some guys have mentioned "whats up with that on a new truck" etc...)
Anyone else have a similar problem?
ok my tundra started doing the same even worse. It would turn over for 8 seconds then just stop when cold. Then start right up all day. So I took it to a friends shop. They did some test and figured out my fuel had to much alcohol in it. Or something like that. He reflashed my computer and I switched gas stations been perfect ever sense. So the F250’s going in this week. It starts right up 90% of the time but barely starts sometimes. Hot or cold
The following users liked this post:
