2017 6.2 random long crank when starting
#92
#93
No reprogram did not fix.... Dealer needs an error code or a fuel pressure out of spec to replace under warranty... I think if they look at pressure when it happens it would get a pump...but good help is hard to find... They start it to bring in shop...by then too late to catch it
#94
#95
#96
ford replaced my fuel pump last summer. It’s been prefect ever since. Figure out how to make it happen. Mine was midday let it sit for a hour or more. It would do it every time. Started great in the morning or if you started it every 20-30 minutes. Good luck.
#97
They admitted it long cranks.... But said Ford will only do the reprogram to solve it.... Unless they get a code or a fuel pressure low reading ..no pump! Reprogram does not solve it.... They had truck twice so far ,for 5 weeks in 2018........ 3 main issues persist... Corporate does not want to help....said find a new dealer... Still under warranty and have Premium care.....gee thanks.
#98
#99
My '18 with 58,000 is doing this as well. Mornings are fine,getting worse with the hot weather after driving and sitting for an hour or so. Have purchased the replacement fuel pump mentioned in this thread, it will be replaced Monday. Stay tuned for an update, as mine is regular as clockwork when hot and sitting for a bit, I should know right away if it helps. Had the "reflash" done back in January...nothing seemed to change, so I'm hopeful.
#100
#101
I simply googled part # HC3Z9H307U. I ordered it from a local dealer and if I recall , the cost was about $134...give or take.This part number is referenced elsewhere in this thread as well. Just make sure you get the part number ending in "U" like above..as I understand it, this is a newer design and supposedly will alleviate our problem. I will post up immediately after pump install to share my results. Not doing myself, it's only a couple hours labor at my local trusted shop, so I'll spring for it.
#103
Sorry for the delay , but wanted a few days of driving to give an accurate report. Had the fuel pump replaced on Monday, which was warm for around here(80's), and have driven several hundred miles all week. The temps have not been warmer than 80's, but I have tried to recreate the issue as often as possible. As of this moment, I have not had a long crank problem since the replacement on Monday. Now, I admit, I may be overly critical of things for a bit, as there was maybe..possibly a time or two that I thought it cranked a second longer than normal...but before, there were times I feared it would not catch and I have definitely not had that happen. I'm cautiously optimistic , but will reserve the declaration of victory for a later date after more time has been spent behind the wheel. Mornings are still crisp starts as always, but in the heat of the day, prior to Monday, there were times it barely caught and it even stumbled and started very slowly when it did. I'm happy to report, that has not happened again....yet. I will post back up when I've had more time to drive, test, and over analyze my results. Again, the cost of the pump was little over $130, my local shop billed at 2 or 2.5hrs labor to swap it. If you can swing it...as of now...I recommend it. Stay tuned for more information...
#104
Just checking in to see if this is still working out for you. I am experiencing the same issue on my 2018.
