95 bronco 5.8 timing issue - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 01-26-2018, 08:48 PM
LLBronco
LLBronco is offline
LLBronco is starting off with a positive reputation.
95 5.8 auto 119k. Still making it mine... Previous owner did a bunch of stuff to it.
So, I've been having an issue with what seems to be a misfire and a slight surging. At idle you barely get a hint of a misfire and the rpms fluctuate approx 100-200 rpm (hot and cold). Throttle (in gear at any point under load) it misses pretty bad. Let off the throttle it smoothes out. I've checked codes... As follows.
24-ACT or VAT sensor out of range
45-Thermactor air flow is always upstream during ERST.
I replaced the ACT (or IAT) and the ECT. No more CEL. But still missing. As far as I can tell there are no vac leaks. Cap, rotor, plugs and wires (plus more) all new. After a bunch of research I'm thinking it's got to do with the timing. I go to check the timing and TDC is on cylinder #4, dead nuts. Will this cause an issue? Is it required that TDC is on cylinder #1? If so do I need to re stab the distributor?
Old 01-28-2018, 05:20 PM
LLBronco
LLBronco is offline
--Removed--
Old 01-28-2018, 09:20 PM
LLBronco
LLBronco is offline
Well it's not a timing issue. I was using the heavy notch on HB as tdc. Then I found the actual numbered etch marks. Have it at 12* btdc atm. I've heard a lot of variations from 10-16* btdc. What are the pros and cons?
Still missing though under load. Pulled codes again. All have to do with the thermactor system and the egr system. I did find a vac leak, black supply from can. That's taken care of but didn't fix the problem. I'll probably just start swapping parts one at a time with some boneyard parts, see if anything makes a difference. If not it'll be new parts.
Old 01-29-2018, 01:48 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
well first off that year should be giving you a 3 digit code so something isnt correct with your 2 digit codes. Stock timing on your motor should be 10*btdc. many guys will do whats called a sixlitre tune up and bump the timing to 12*.
a vac leak will cause surging, as will a bad tps. If the vac lines are stock i would suggest replacing them with rubber lines.
TDC must be on cylinder #1 and your distributor rotor should be pointing to #1 post on your dizzy cap. so if this isnt happening then you need to pull and restab the dizzy.
are the plugs new and if so what brand/type. how do the plug wires look? is the coil stock?
Old 01-29-2018, 07:44 PM
LLBronco
LLBronco is offline
The timing is squared away. I couldn't tell with codes, some seemed like they should've been 2 digit and others seemed they could've been 3 digit. Plugs are newer Motorcraft platinums, wires are newer super stock accels with heat protection by the headers, coil is aftermarket (accel). I had planned on swapping all vac lines to rubbers.
Old 01-30-2018, 11:34 AM
Kemicalburns
well the plat plugs are known to not perform well on our rigs. copper motorcraft or autolites perform the best.
I would also recommend going back to a motorcraft coil. make sure you have the plug wires separated and keep #7 & #8 wire from crossing/touching as those are prone to cross fire causing a stumble.
Old 01-31-2018, 06:35 PM
Redark1
Redark1 is offline
Redark1 is starting off with a positive reputation.
seeing how it hasn't been stated yet, did you pull the spout when setting the timing.
compression test would be good to rule out a bad cylinder.
Old 02-04-2018, 01:46 AM
LLBronco
LLBronco is offline
Alright... So I swapped the plats for Motorcraft coppers and I happened to stumble across a half melted #4 wire (previous owner had done some of his own work to it) caused by it practically laying on the header. Fixed that. Tore the whole upper intake off, cleaned everything (throttle body, iacv and manifold were pretty caked in carbon deposits), replaced all vac lines with silicone, new pcv, new tps. Also checked the timing, again. Initial reading was, apparently, 26*btdc with the spout in cold. Let it heat up, shut it off, pulled spout and set the timing at 10-11*btdc. Shut off/restart spout in... Now the timing is at about 15-16*btdc. Is that normal for it to be higher with the spout in? Some sort of computer adjustment? It sounds and runs great.
Old 02-04-2018, 10:19 PM
EDC8008
EDC8008 is offline
EDC8008 has a good reputation on FTE.EDC8008 has a good reputation on FTE.
Yes that’s one of the items the ECM controls.
Old 02-05-2018, 12:35 PM
LLBronco
LLBronco is offline
Now my battery light is on... All the time. Battery gauge says everything is good. I took it to autozone to get the charging system tested and everything checked out. A poorly connected ground wire I'm guessing? It stalled once but fired right back up. Only issue now.
Old 02-05-2018, 12:38 PM
Kemicalburns
i believe there is a ground wire that connects to the upper intake. also one towards the back of engine to the body.
great work and yes the system advancing like that with spout plugged in is correct.
1980F1
08-30-2006 08:54 PM
mshumack
09-19-2002 03:44 AM
Ford79
19
09-13-2002 12:17 AM
Critterhunter
Ranger & B-Series
09-10-2002 10:21 AM
Bull
10-03-2001 09:52 PM
Quick Reply: 95 bronco 5.8 timing issue
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
