This will either be a part out or a fix and sell Excursion
#31
Did you run it for codes yet?
Make sure you post up in the 7.3L section so the guys there can help you get squared away too.
Stewart
#32
This is going to sound really stupid, but check all the wiring connections. I've had multiple cars fail to start because of loose connections. Check the connections to the PCM too.
OP has a V-10 excursion. His last project was a 7.3 F350.
#33
But, that does make it easier to figure out!
Stewart
#34
#35
#38
I'm glad I could help! That issue had us stumped for awhile, finally after testing figured out what was happening. The cable looked fine but had an issue somewhere in the line.
#40
Corrosion kills. We dealt with this in military wiring all the time. Can't usually see it, but it can be tested for fairly easily.
#41
we cut the whole cable apart along with ends, it made no sense what so ever, everything was still shiny no corrosion. Oddest thing I've ever came upon.
#43
on
So after replacing a few of the coil packs and plugs; the knock is still there. It is definitely coming from the bottom end of the engine. It is time to throw in the towel and part it out.
Thanks for the help everyone.
As soon as this is gone, I will be on the look out for another one. I have to keep this little projects around so I can fund the projects on my truck...
unofornaio
19
09-21-2014 06:14 PM
jabdmnd2b
04-07-2012 07:50 AM
rfish84
12-08-2005 06:41 PM
78f3504x4
06-10-2004 08:01 AM
