Power steering noise
03-11-2018, 07:34 AM
Hi all. My power steering is making noise when turning. Is the pump going south or does it need new fluid? The fluid level is full, so no leaks. Thanks.
03-11-2018, 08:09 PM
It could be a few different things, but I'd try fresh fluid to start. Has the fluid ever been changed?
03-13-2018, 07:50 AM
Changing the fluid seems to have fixed the problem. I did not have the van new so I might be the first to change it.
thanks for the tip.
03-13-2018, 08:47 AM
Glad to hear it was an easy fix!
03-15-2018, 06:54 AM
How do you go about draining the fluid? Is there a plug to remove or do you have to remove a hose?
03-15-2018, 08:50 AM
Quote:
Originally Posted by
jeffreyclay
Turkey baster.
OSMan93
05-30-2015 09:52 AM
F250W6.0
01-28-2012 09:05 AM
Monkeys7.3
05-27-2010 06:58 PM
rickdb1
19
12-19-2006 02:18 PM
bremen242
1997 - 2003 F150
11-06-2005 09:32 AM
