Stealth HPOP
Old Jan 25, 2018 | 03:18 PM
fyrehose's Avatar
fyrehose
Stealth HPOP
I am preparing to take my stealth pump out due to a leaky back cover. Does anyone know if there is a gasket that seals up the back cover? I want to have as little down time as possible. If there is no gasket, what do you recommend I use to seal it. Something to hold about 3500 psi.
Old Jan 25, 2018 | 10:43 PM
coax9952's Avatar
coax9952
Nice Try, The HPOP has several Orings, seals, and Gaskets that all leak when they get old. If you're gonna replace one, you've gotta pull it to replace most of them. the big round plate in the Back has a circlip holding it in, an Oring under that.... You can get a rebuild kit from the Diesel-O-rings site that has them all.... Good luck
Old Jan 26, 2018 | 01:03 PM
fyrehose's Avatar
fyrehose
Here is the pump I have.
https://www.ford-trucks.com/forums/a...1&d=1516993304
Old Jan 26, 2018 | 06:43 PM
coax9952's Avatar
coax9952
I've never seen that one before, Can you get a exploded diagram from the Builder? I was describing a stock one to you before....Sorry. I suspect there is still going to be some seals somewhere, how long has it been run?
Old Jan 26, 2018 | 08:29 PM
Dan V's Avatar
Dan V
As far as I know, Stealth is out of business. There were a lot of people who had trouble with the pump.
Old Jan 29, 2018 | 02:14 PM
fyrehose's Avatar
fyrehose
I believe there were alot of problems with the SRP 1 and 1.1 pumps. This pump is a stage one which is completely different. I don't recall any problems with the stage I. They probably didn't sell many due to the high cost. I believe the stage I was $2000+.
parr4
Oct 12, 2010 01:42 PM
xbigbuckleyx
Feb 9, 2010 10:37 PM
ar156920
Aug 4, 2009 01:11 PM
bshackelford711
Jun 29, 2005 07:31 PM
MARC
Jan 16, 2005 03:21 PM
