Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
plastic fuel filter on the top of the engine
Old 01-24-2018, 08:08 AM
605ma
605ma is offline
605ma is starting off with a positive reputation.
in my previous 6.7 power stroke TD the plastic in line had 2 inlet/outlets, now my 17' has a third one that's thinner, and smaller. just trying to understand why Ford made this change and what purpose does this third inlet/outlet serve.
thanks
Old 01-24-2018, 08:19 AM
graysonp
graysonp is offline
graysonp is starting off with a positive reputation.
The third inlet is for filling/priming the fuel system when the truck is built. The first filter that comes on the new truck has 3 inlet/outlets. All replacement filters only have two.
Your last 6.7L would have had 3 also when it was new, you may just not have noticed at the time.
EDIT: I stand corrected. I didn’t realize the 17 actually had the third line.
Old 01-24-2018, 08:31 AM
Superdave71
Superdave71 is offline
Superdave71 is gaining momentum as a positive member of FTE.
Grayson, the 17ís have three that are plumbed up. Iím not sure of the purpose of the third either.
Old 01-24-2018, 08:35 AM
F250_Super_4X4's Avatar
F250_Super_4X4
F250_Super_4X4 is offline
F250_Super_4X4 is gaining momentum as a positive member of FTE.F250_Super_4X4 is gaining momentum as a positive member of FTE.
I believe the third is the return line to the tank on the 17s
Old 01-24-2018, 09:26 AM
605ma
605ma is offline
thank you for the quick response.
Old 01-24-2018, 10:19 AM
dirthawg's Avatar
dirthawg
dirthawg is online now
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
This is not always the case. Ford must have made a change at some point. I changed my fuel filters for the first time this last weekend on my '16 with only one inlet and one outlet. I watched a few youtube videos to get familiar with the process before changing mine and noticed they all had a 3rd pipe, so when mine didn't have that 3rd pipe I noticed right away. Those trucks in the videos were 2011 and 2012's FWIW.
I also completely forgot about the fastener that holds the engine mounted filter in place. Either my truck doesn't have that fastener or I got lucky and removed it without needing to loosen it, mine came out relatively easily with a counter clockwise twist.
Old 01-24-2018, 01:09 PM
jav_eee
jav_eee is online now
jav_eee is gaining momentum as a positive member of FTE.jav_eee is gaining momentum as a positive member of FTE.
The 15 and 16 models (maybe earlier) don't have the tension screw that the older models do. You just twist the filter and pull up.
Old 01-24-2018, 04:34 PM
F250_Super_4X4
2011 -2016 MY original from the factory will have three tubes, but the tube closest to the grill will be sealed. When you execute a filter change there will only be 2 tubes. 2017 MY replacement filter have 3 tubes and 3 connections.
Old 01-24-2018, 06:18 PM
dirthawg's Avatar
dirthawg
I forgot to mention I purchased my truck brand new with only 24 miles on the clock 6 of those miles was the test drive. So either it came from the factory with only 2 tubes or it was changed before I took delivery (highly unlikely). I certainly can't be the only one?
Original filter I removed last weekend. Pulled it out of the trash to make sure I wasn't mistaken.
Old 01-25-2018, 05:03 PM
Superdave71
My 16 only had two tubes from the factory.
phoneman91
Paint & Bodywork
04-28-2016 07:59 AM
shorebird
General Automotive Discussion
01-19-2012 03:43 PM
wickware
06-14-2010 07:18 AM
fin1
04-04-2010 05:34 PM
Quick Reply: plastic fuel filter on the top of the engine
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
