Cutting my firewall to remove A/C - Ford Truck Enthusiasts Forums
Old 01-23-2018, 11:36 PM
hail destroyer hail destroyer is offline
hail destroyer is starting off with a positive reputation.
Im cutting the firewall section out of a non-A/C truck, and will MIG it onto my 78 supercab to get rid of the HUGE factory A/C unit, which will make changing plugs, headers, plug wires etc, much easier.
Ive got all the non-A/C ductwork and heater controls cleaned up and ready to go.
Anyone else done this? foresee any troubles? The cut is from a '75.
Thanks.
Old 01-23-2018, 11:52 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
It's been done before, measure twice, cut once. It is a BIG hole to fill, so cut ALOT of doner firewall out.
Are you going to just dead off your old a/c dash vents?
Old 01-23-2018, 11:53 PM
jimlj jimlj is offline
jimlj has a good reputation on FTE.jimlj has a good reputation on FTE.jimlj has a good reputation on FTE.
I had to do the same thing you are talking about when I installed my Cummins. The turbo and exhaust didn't play well with the Ford AC box.
I used seam sealer and rivets instead of welding. Make sure you get your firewall piece in properly so the heater box lines up and seals tight on the cold air intake on the kick panel. You will need the defrost ducting as well as the ac type duct won't line up properly with the heater box.
Old 01-24-2018, 03:12 AM
wow! detail. I appreciate this much guys
Old 01-24-2018, 08:55 AM
77&79F250's Avatar
Used OEM parts guy
Found a thread about this exact subject. https://www.ford-trucks.com/forums/1...l#post17505709
Old 01-24-2018, 10:01 AM
twinzilla twinzilla is offline
twinzilla is starting off with a positive reputation.
Subscribed, haven't done it but may in the future (have a decent AC cab that I may use for a non-AC project).
Old 01-24-2018, 01:15 PM
gittinwidit gittinwidit is offline
gittinwidit is starting off with a positive reputation.
I've done this. Really quite easy. I glued mine in.
Non AC firewall sections are now on my list of items I torch off of carcasses ready for the scrapyard.
Old 01-24-2018, 01:19 PM
Aaron-71's Avatar
Aaron-71 Aaron-71 is offline
Aaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to behold
Quote:
I really need to update that thread with my dimensions and a better description of what I did.
Thanks for the reminder Rich! lol.
I should also plan to do a detailed description of what I eventually end up with in terms of installing a heater box in place of the A/C system.
These old trucks are cold enough... we need heat for Saskatchewan weather sometimes (even on random summer days).
Old 01-24-2018, 03:25 PM
FuzzFace2's Avatar
FuzzFace2 FuzzFace2 is offline
FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.
Given enough money & time anything can be done!
Not on a 73-79 truck (81 F100) and not AC to Non-AC but Non-AC to AC.
Started with this non-AC fire wall.
The AC fire wall to go in
Non-AC fire wall cut out
AC fire wall clamped inplace
Welded in place
Primed & painted
Not the easy way but I wanted the factory look and why I did it that way.
Dave ----
Old 01-24-2018, 06:11 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
I've done this too. I just wished I'd have had some new padding to put on the inside. I don't know if anyone sells the exact replacement but I'm sure you could find something close to use.
Old 01-24-2018, 06:17 PM
77&79F250's Avatar
Used OEM parts guy
Dyna mat, boom mat, peel and seal...
A/C block-off plate... Need some dimensions Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 20 10-09-2017 03:20 PM
1985 F150 A/C Install Help Please Atlfan65 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-08-2017 12:37 AM
WTB F 250 Cab 1977 1984montemaniac WTB - Parts & other 6 08-05-2017 07:12 PM
Adding AC to a non-AC 1995 F250 kevh481 1987 - 1996 F150 & Larger F-Series Trucks 1 07-06-2016 09:49 AM
Which heater core Uni Moe 1967 - 1972 F-100 & Larger F-Series Trucks 1 04-10-2016 07:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
