97 7.3 auto. Won't shift out of park while running. - Ford Truck Enthusiasts Forums
Old 01-23-2018, 09:48 PM
Ezalycasaid's Avatar
Ezalycasaid Ezalycasaid is offline
Ezalycasaid is starting off with a positive reputation.
I just tried to hook up my new trailer to the obs and when I did everything worked besides brakes. Rewired it then everything worked. But I couldnt get the shifter to get out of park with it running. I can get it to go out of park with the key turned to accessory. Then start it in neutral, then shift fine. Any ideas, I'm thinking I popped a fuse with the wrong trailer wiring.
thanks guys
Old 01-23-2018, 10:27 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Do the brake lights work?
Sounds like maybe the trailer brakes were connected to the brake light circuit, rather than to the brake controller.
Old 01-23-2018, 11:36 PM
They do not good guess. Any idea what fuse that connects to?
Old 01-24-2018, 12:17 AM
Fuse assignments are in the owner's manual.
Old 01-24-2018, 12:56 AM
Bluediesel250 Bluediesel250 is offline
Bluediesel250 is starting off with a positive reputation.
And on the back side of the little cover you pull off the fuse panel down by your left knee, all of the fuses are listed there
Old 01-24-2018, 06:21 PM
Thanks guys. It ended up being one of the tiny braided wires snapped and the ground and hot brake wire where touching. Clipped it and replaced the #13 fuse. Works great now.
Old 01-25-2018, 02:08 AM
Glad you got it figured out!
Old 02-16-2018, 06:29 PM
Quote:
Thanks again!
Shift Lever Sticks in Park 04scurs 6.0L Power Stroke Diesel 6 05-05-2017 02:27 PM
98 Automatic 2.5 shift lever stuck sometimes in PARK 1998Ranger25L153CID Ranger & B-Series 3 01-01-2017 09:52 AM
Really hard to shift from park with engine running when cold? hasteranger Excursion - King of SUVs 8 12-20-2016 08:03 PM
Cold truck won't shift out of park while running. hasteranger 6.0L Power Stroke Diesel 4 12-20-2016 07:41 PM
15' brake controller question levi'sford 6.7L Power Stroke Diesel 20 04-14-2016 04:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
