Always something, but I love her anyways. - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
  #31
Old 02-02-2018, 07:30 PM
Sous's Avatar
Sous
Sous is offline
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Those do look good! I look forward to your road review/opinion. They are in my cart, just waiting for me to hit the purchase button.
  #32
Old 02-03-2018, 11:11 AM
SaintITC
SaintITC is offline
SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.
I installed the new style mirrors awhile ago. There is much more viewing area, and the shrinky dink ones are fabulous. I can see the rear tires while reversing, great for getting into tight spots.
  #33
Old 02-03-2018, 11:18 AM
Sous's Avatar
Sous
Sous is offline
What do you mean by "shrinky dink"?
I have been set on getting these mirrors for a while, so it has been a long time coming.
  #34
Old 02-03-2018, 01:56 PM
afmedic
afmedic is offline
afmedic has a good reputation on FTE.afmedic has a good reputation on FTE.afmedic has a good reputation on FTE.
I think he's talking about the spot mirrors on the bottom
  #35
Old 02-03-2018, 04:38 PM
Sous's Avatar
Sous
Sous is offline
Oh ya, I can see now that the term fits.
  #36
Old 02-03-2018, 04:40 PM
afmedic
afmedic is offline
I'm getting ready to go put mine on, I'll let you know how they do on the highway in the morning!
  #37
Old 02-03-2018, 05:42 PM
Sous's Avatar
Sous
Sous is offline
Cool! Hope the install goes well and I look forward to your review.
  #38
Old 02-03-2018, 05:48 PM
SaintITC
SaintITC is offline
Yes, the bottom wide view mirrors. I actually use them exclusively for regular driving, the huge upper ones are better for use with a trailer. I have them pointed out rather far. While some folks think these mirrors are too large, there are zero blind spots with them.
  #39
Old 02-03-2018, 07:03 PM
afmedic
afmedic is offline
Mirror review part 2
Installation is complete...and as my title states, there's always something. Found out my mirror switch is bad and won't go to the right! New one on order.
There is a plastic tab in the first picture that needs to be cut to look like the second picture. The only other thing that needs to be done is file the round base of the studs to fit the outer door skin and rest on the inner. I didn't have a file with me, so I made the outer hole a little bigger with a socket and they popped right in. Hooked up the adapters, and they work great. Still need to do the marker light, but saving that for a later date.
X shaped plastic needs to be removed
X shaped plastic removed
  #40
Old 02-03-2018, 07:22 PM
Sous's Avatar
Sous
Sous is offline
They look sharp, nice job. I look forward to your road test review.
  #41
Old 02-03-2018, 07:32 PM
afmedic
afmedic is offline
I'll have one for ya in the morning! I slammed the door really good a couple times and watched the glass and there was no more movement than the factory dog ears, so I have high hopes they will do well on the highway.
Now to dive in and do my CAC/plenum boots!
  #42
Old 02-03-2018, 09:15 PM
afmedic
afmedic is offline
Leaky boots are gone!
  #43
Old 02-04-2018, 07:05 AM
afmedic
afmedic is offline
Mirrors part 3
So I drove in to work this morning about 30 miles on the highway. The mirrors did great! No vibrations at all! And my truck even has a pretty bad vibration at 65 because of the tires. Even through that, the mirrors didn't vibrate. I can confidently recommend these mirrors! Even with the little bit of modification required, the $500 savings over OEM is well worth it.
I also saw my boost hit 18 for the first time this morning after replacing all my boots last night, and I don't hear rushing air all the time now!
  #44
Old 02-04-2018, 07:46 AM
Sous's Avatar
Sous
Sous is offline
Done! Thanks for the road test and honest opinion about the mirrors. I didn't quite understand the need for the studs to be filed, but I am sure I will when I start working on them.
  #45
Old 02-04-2018, 07:50 AM
afmedic
afmedic is offline
The way the doors are, there is an outer skin and inner skin. There is a big hole in the outer skin, and the studs go through that to rest flush on the inner skin. The studs in the new mirrors are ever so slightly larger than the hole in the outer skin on the bottom 2 holes, so the mirror won't sit flush. You can drill the holes bigger, but in order to do it without fooling with the truck you can file the base of the studs to fit through the holes
Quick Reply: Always something, but I love her anyways.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
