Factory 302 Breather Setup
Does anyone have photos of what the valve cover breather setup looked like from the factory on a 1986 F-150 EFI 302? Want to make sure mine is setup correctly from the PO. Also wondering if anyone has any thoughts on what might cause a bit of oil to be making its way out of the breather?
A little bit of oil means your PCV valve is clogged or not working for some reason, or your engine has a little bit of wear to it, and a little bit of blow-by. When the engine is new, the PCV valve actually puts a slight draw on the inside of the engine. Fresh air is let into the engine through the pipe going to the aircleaner.
As the engine gets older and the rings wear, more and more pressure from the combustion chamber gets past the rings and goes inside the engine. This naturally gets worse and worse till the PCV valve can't handle all the volume. So some pressure starts building inside the engine, and instead of sucking in fresh air from the aircleaner, the pressure inside the engine relieves itself down the pipe into the aircleaner. There is always some oil smoke involved in all this, and that is were the oil comes from.
PO removed the factory intake box and hacked up the tubes for a crappy intake setup. Now I can't find the stock setup or an aftermarket one. Any ideas? It looks like the drivers side is a straight vent line from the oil filler to the air box but no PCV, am I seeing that correctly? Any ideas on where to send it not that I don't have an airbox to connect it to? Appears the passengers side is connected, but I'm going to replace it anyway. It's also missing a cap on the upper elbow. Going to do valve cover and upper manifold gaskets possibly this weekend so I'll fix the passenger side then. Can I put a tee in the upper manifold instead of the elbow and connect both there or is that a no-no since it's after the throttle body instead of before it like the factory setup was?
EDIT: After doing a little more research last night, it appears that I'm probably ok just venting the drivers side to atmosphere. Wondering if it just needs a new grommet to seal things up, the breather that is on there is a little loose.
All these places in Colorado claim to have a 5.0 engine to fit your truck. If they have the engine there, they may still have the truck or Bronco there with the aircleaner you need.
1986
Engine Assembly
Ford Bronco 5.0,AOD,4X4,CORE,CORE,CORE 149,159 A 866086 $Call A-1 Auto and Truck Recyclers USA-CO(Penrose) Request_Quote 719-372-6588 Request_Insurance_Quote
1985
Engine Assembly
Ford Truck F150 5.0L,RUNS GOOD 130135 $500 Adam's Wrecking USA-CO(LaJunta) E-mail 1-800-748-2332
1986
Engine Assembly
Ford E150 Van AT,RWD, CK 150004 $500 Adam's Wrecking USA-CO(LaJunta) E-mail 1-800-748-2332
1985
Engine Assembly
Ford Bronco 5.0L,A,04/85,MFI,4X4 RE0030 $450 Trade Center Auto Recyclers USA-CO(Rifle) Request_Quote 970-625-1499 Request_Insurance_Quote
1986
Engine Assembly
Ford Truck F250 CHECK 1ST,5.0L (VIN N, 8th digit)-0MI JG4271 $Call Lon's Automotive USA-CO(Bayfield) Request_Quote 970-884-7100 Request_Insurance_Quote
1986
Engine Assembly
Ford Truck F150 5.0L (VIN N 8th digit) 120+ COLD COMP 30 DAY WARRANTY EXCHANGE PULLED ON SHELF 25% RESTOCK A31256 $500.16 Martin Supply Parts Vintage to Recent USA-CO(Windsor) Request_Quote 970-686-2460 Request_Insurance_Quote
1986
Engine Assembly
Ford Truck F150 5.0L (VIN N 8th digit) 5.0L HISTORY UNKNWOWN YOU PULL. EXCHANGE. 87,000 00031256 $300.15 Martin Supply Parts Vintage to Recent USA-CO(Windsor) Request_Quote 970-686-2460 Request_Insurance_Quote
1986
Engine Assembly
1985
Engine Assembly
1986
Engine Assembly
1985
Engine Assembly
1986
Engine Assembly
1986
Engine Assembly
1986
Engine Assembly
The 2nd picture is the PCV and if I understand it right the 3rd picture is the other end of the PCV. If so that would be right that it goes into the intake chamber.
The other side or breather, do you have a close up of it? Should have a hose that went to the stock air filter box.
It should pull filtered air into the motor and out the PCV to complete the loop.
Dave ----
Dave ----
jasindude1
04-16-2016 04:24 AM
68murc
10-12-2008 07:20 AM
