is 55psi of boost to much - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-22-2018, 07:08 PM
biggreen6.4
biggreen6.4 is offline
biggreen6.4 is starting off with a positive reputation.
I have a 2008 f350 I habe a bullydog tuner in It. its fully deleted with o-ringed heads and arp head studs. should I be worried about blowing a head gasket with 55 psi of boost?
Old 01-22-2018, 08:17 PM
73F700's Avatar
73F700
73F700 is offline
73F700 is gaining momentum as a positive member of FTE.73F700 is gaining momentum as a positive member of FTE.
How often and for how long?
55 psi is a lot of boost. If the o-rings and studs were done right you might not have any trouble with the head gasket but you may have trouble in other areas, turbo for instance...
In my opinion any 6.4 that is taken that far beyond stock form has a limited life span. It is very easy to tune a 6.4L to blow the doors off most other comparable trucks, they also tend to explode more than most other comparable trucks.
Don't know if it answers your question - if you are looking for a guarantee on here you won't be getting it...
Old 01-22-2018, 08:34 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
6.4 pistons are another point of failure....they like to melt under pressure
so the 55lb boost question.....if you are getting this with a tuner only with no added cooling...ingredents for trouble.
but if you are getting 55lbs of boost and it involves methonal/water injection at 640ml flow rate or better...I would be more comfortable as the methonal/water enjection provides a tremondous amount of cooling.
what your exhuast temps and get a coolant PSI gage.
Old 01-22-2018, 08:41 PM
biggreen6.4
it only did it twice an d maybe 15 seconds each time
Old 01-22-2018, 08:53 PM
73F700's Avatar
73F700
73F700 is offline
If you are concerned about something that has happened in the past, that's one thing - if you are asking what you can safely push on an ongoing basis that's another.
I would personally set defuel levels to around the 40 psi mark, I wouldn't normally go over 35 psi at WOT in my truck.
BolognaBlake
03-23-2018 10:19 AM
thomil18
6.7L Power Stroke Diesel
11-14-2015 10:15 PM
Smokin'
22
07-23-2006 01:07 PM
roadwarrior2500
01-05-2005 06:54 PM
mtstormcars
11-21-2003 07:25 PM
Quick Reply: is 55psi of boost to much
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
