Turn signal wiring - Ford Truck Enthusiasts Forums
Turn signal wiring
Old 01-22-2018, 06:15 PM
rsylvstr rsylvstr is online now
rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.
Turn signal wiring
Aka multi function switch.
Typical tilt the steering wheel down, something goes wrong. Mine was the right rear turn signal wouldn’t work and gave me the “fast blink” like a bad bulb.
Took the three screws out, popped apart the collar around the steering column and then pried off the ignition switch (just the black part) so I could slide the upper part of the column up the transmission select lever.
The pics are what I was faced with.
Hitting NAPA tomorrow so I can get a few square connectors.
Brushing on two layers of liquid electrical tape on the exposed wires you see so I don’t have to take them out.
Shocked how loose ALL the connectors are. Wish me luck in putting tje three wires in the right spot. I have a schematic but don’t think it matches.
The lone wire insulation with no wire showing looks like it has been that way for a while. Unsure what it goes to but I didn’t notice anything not working.
Old 01-22-2018, 06:40 PM
These are the two parts of anyone needs to replace. I’m hoping I don’t.
Motorcraft WPT611 (says 9 leads. Mine uses 7)
And WPT179
Old 01-22-2018, 09:17 PM
Looks like it is “trailer tow [email protected]
WTH does that do?
https://ww2-secure.justanswer.com/up...2_234909_2.gif
Old 01-22-2018, 09:19 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.
That drawing's description is screwy, I saw the same thing in my EVTM. I suspect it's an error.
The orange/light blue is the feed to the right rear stop/turn lamp according to the schematics.
Old 01-22-2018, 09:21 PM
Thanks! Shocked it was working at times the way that looks
Old 01-22-2018, 09:22 PM
Any more accurate drawing you have seen?
Guessing where those three go.
Surprised the Motorcraft oem plugs with pigtails, all the pigtails are black.
Old 01-23-2018, 01:03 PM
alloro alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
Quote:
You're not the first, a lot have had this same issue which is a result of the tilt wheel going up and down with a wiring harness that has little to no slack.
Old 01-23-2018, 01:24 PM
After stopping at four NAPA stores, I don’t think they have this size.
Bought two at ford, come with pigtails which is a good thing.
PN 101041. $8.70 total with tax for two.
That and some liquid electrical tape to try to hold the rest of them in.
****these are 14 gauge and the originals are 18 gauge. Will that provide too much resistance??? ***
Old 01-23-2018, 02:57 PM
Sam I Am's Avatar
Sam I Am Sam I Am is offline
Sam I Am has a good reputation on FTE.Sam I Am has a good reputation on FTE.
Something I am curious about, do other people adjust the steering wheel tilt every time they get in and out of the truck? Because for me it is a one time deal, set it how I like it and that's where it stays.
Old 01-23-2018, 03:36 PM
Adjust each time
Old 01-23-2018, 04:22 PM
Sam I Am's Avatar
Regarding the all black wiring, it may have small printing on each wire that describes each circuit. Many manufacturers do this even to harnesses with different colored wires to accommodate color blind people. I have also seen some contractors order their extension cables and air hoses with their company name printed every foot or so along the entire length of each piece.
Adjust each time
I kinda figured that, I guess what I should have asked is why do you find that necessary? Because I have never had an issue with the tilt mechanism or related wiring in any vehicle I have owned, so it may be that manufacturers do not design them to withstand so many cycles of movement. So with that possibility in mind, what would make you feel the need to adjust it each time while I do not feel that need?
Do you prefer to drive with it all the way down?
Are you a large person or are certain aspects of your physical presence disproportionately sized (BMI/BCA %?) that it requires the steering wheel to be out of the way for ingress/egress?
I don't mean this to sound like "me good, you bad" but there is obviously something getting overworked to result in some users trucks breaking from repeated use while others have no issues.
I set mine so that it as low as possible while still being able to view all the gauges. And at that setting I am easily able to climb in and out comfortably with no issues. I am pretty much an exact "crash test dummy" size low BMI, 6' even, etc.
Old 01-23-2018, 05:21 PM
one word, habit.
Old 01-23-2018, 05:22 PM
I picked up 14 gauge pigtails.
**** the originals are 18 gauge. Will that provide too much resistance??? ***
Old 01-25-2018, 02:55 PM
Quote:
Some people share a vehicle and the seats, mirrors, and tilt wheel are always getting adjusted.
Old 01-26-2018, 05:52 PM
All fixed. Probably saved 2-3 hours of book labor.
Slathered liquid electrical tape.
Replaced one of the wire ends with pigtail.
Tested. Wiper functions all checked good. Flash to pass. High and low beams. All good.
No hazards.
No blinkers.
Nooooooo. So I figured the switch was bad or the top plug was AFU.
RTFOM. Sure enough, 20a fuse was blown. Probably because I never disconnected the battery or pulled a fuse before working on it.
Buttoned her up and now we can haul the wheeler and ride tomorrow.
2017 CHRISTMAS EPISTLE jniolon 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 12-07-2017 02:32 PM
Christmas Epistle 2016 jniolon 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 12-17-2016 08:20 PM
2006 Ford F350 6.0 diesel INTERMITTENT no crank JC155 6.0L Power Stroke Diesel 7 09-13-2016 11:56 PM
My Installation - Python 533 Remote Start/Alarm in 2003 F250 whiteoak11 1999 to 2016 Super Duty 12 06-03-2016 06:34 PM
Starting my 1982 F100 build IsaacJR75 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 34 04-17-2016 12:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
