Oil volume and temp
Oil volume and temp
Pretty interesting I check my oil pretty often. When we were really cold I thought I was losing oil because I keep it about in the middle and in 30-40f it was reading at the min. Now today it's 74f here and I'm back in the middle. I always check it after not running 12+ hours.
reason most manuals say to check the stick a few minutes after turning OFF the warm engine...
so temperature of oil will be near the same..
like any fluid.. it changes with temperature...
like mercury in a thermometer ,,, later colored alcohol
also remember motor oil.. 5w20, 10w30.. will also be different..
remember a "Little" LOW on oil is better then "OVER" full..... fyi.
BuckHammer
13
09-20-2012 10:01 AM
