Anyone else loose the turbo v band bolt? - Ford Truck Enthusiasts Forums
Old 01-21-2018, 05:09 PM
T-wood T-wood is offline
T-wood is starting off with a positive reputation.
I know it's a terrible ?. But in the middle of uppipes. I lost the bolt for the v band clamp from turbo to collector. I had to remove it to get it out. I heard it fall. I've looked everywhere...what I need to do is turn the truck upside down and shake it!
Alright flame on....and any suggestions appreciated.
B
Old 01-21-2018, 05:29 PM
Walleye Hunter Walleye Hunter is offline
Walleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to all
Look on top of the tranny.
Old 01-21-2018, 05:57 PM
I did. I looked for it topside...felt around from below. Crawled all over looking. After an hour of this I gave up. Napa had an exhaust clamp that looked exactly like it. So 35$ later I'm back at it.
Old 01-21-2018, 06:44 PM
AllaboutMPG's Avatar
AllaboutMPG AllaboutMPG is offline
AllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to behold
mechanics mirror on stick is how i usually end up finding lost hardware
similar to this
Amazon Amazon
Old 01-21-2018, 06:49 PM
hydro man 17 hydro man 17 is offline
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
There is an outfit that specializes in hardware of all kinds. I think it is called Fastenall but I am not sure. Brain f**t at the moment.
Old 01-22-2018, 07:22 AM
SaintITC SaintITC is offline
SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.
I dropped a short 8mm socket years ago changing out the DS battery. Found it last fall sitting inside the frame rail when I was looking for the longer 8mm socket I had just dropped...
Old 01-22-2018, 11:31 AM
Sous's Avatar
Sous Sous is offline
Sous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant future
Not on the truck, but still a funny story.
Years ago I drove a 1997 Supercharged Grand Prix. I was changing the oil and knocked the oil fill cap off the top of the engine. It did not hit the floor. I looked for a very long time for that thing, and never did find it. I had a buddy drive me to the nearest Napa and bought a filler cap that would fit the common 3.8 liter. 3 years or so later I was changing out one of the headlight housings and found the cap lodged between the sub-frame and the radiator...
I picked it out of there and laughed at it for a second, then threw it at the trash can nearly as hard as I could...
Old 01-22-2018, 11:50 AM
It is amazing how far and in what direction stuff will travel when dropped. When I'm at my wit's end and trying to find something that fell I take something as similar to it as I can find and drop it the best I can in the manner which the first one fell. I have found a few lost articles that way, not all but some.
Old 01-22-2018, 12:00 PM
The extended bolt for the p/s valve cover, the ones that the GPR mounts to. I dropped one over the exhaust manifold, never found it. So I did what you said, drop the other. I now have two studs with nuts holding the GPR in place.
Old 01-23-2018, 06:57 AM
Tugly's Avatar
Tugly Tugly is offline
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
I have a magnet extension that's pretty powerful, and I keep it at the ready every time I work over the engine. That thing gets its fair share of use... it's strong enough to retrieve the wrenches I drop.
Old 01-23-2018, 05:10 PM
friskyjake friskyjake is offline
friskyjake is starting off with a positive reputation.
Magnet
I know this story does not relate to bolts & nuts. Way back in 1974 I ordered a new ford f250 4x4 auto xlt truck. I came with a 360 fe engine, I drove it home to the shop[12 miles] & pulled the engine & replaced it with a 1968 fe 427 side oiler engine. I did not care about warranty then. After getting use to the truck , I did some hard burn outs. Wow with 4.10 & fords posi it was quite exciting till I broke a L side axle . Anyways to get some of the axle junk out I needed a magnet. Well I needed a a really strong one to pull some of the big pieces out. I found a telescope magnet that will lift a 3ilb weight. It worked. I keep the magnet covered with a 1 inch heater hose & it stays in my truck. Now I,m a lot older & I don,t do that with my powerstroke f350. Thanks for reading, Friskeyjake
C6 Transmission 2nd gear Intermediate band skidsteerman Clutch, Transmission, Differential, Axle & Transfer Case 2 12-02-2017 10:52 AM
up pipe to turbo v-band clamp issue Shattered 1999 - 2003 7.3L Power Stroke Diesel 9 08-02-2017 09:35 PM
c6 band socket size/tool ? jakeharp Clutch, Transmission, Differential, Axle & Transfer Case 1 03-17-2017 10:29 AM
c6 band socket size/tool ? jakeharp 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-10-2017 09:14 PM
RAG JOINT ? 72CC428 1967 - 1972 F-100 & Larger F-Series Trucks 15 05-14-2016 02:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
