want 300 l6 to make more power - Ford Truck Enthusiasts Forums
Old 01-21-2018, 01:19 PM
1959.....f100 1959.....f100 is offline
1959.....f100 is starting off with a positive reputation.
Hello! I have a 85 flareside and wanna know what i should do to the 300 to make it more powerful?
Old 01-21-2018, 03:21 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
You can put the standard hop-up parts on it, like a new intake, small 4 bbl carb, etc. But speed parts for the six are very expensive compared to the v8's. And your results may not be that dramatic.
It's better to appreciate the old 300 six for what it is, a over built low horsepower work horse that will work for you all day, and get you there and back reliably. It's not a race engine.
Old 01-21-2018, 04:41 PM
maytag906's Avatar
maytag906 maytag906 is offline
maytag906 is gaining momentum as a positive member of FTE.
Make sure it's running properly, that the timing is right, etc, before wanting to improve it.
Old 01-21-2018, 05:13 PM
82_F100_300Six's Avatar
82_F100_300Six 82_F100_300Six is offline
82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.
My 300 will do just about anything I ask of it.
Just not in a hurry.
Old 01-21-2018, 06:25 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014 NotEnoughTrucks2014 is offline
NotEnoughTrucks2014 has a very good reputation on FTE.NotEnoughTrucks2014 has a very good reputation on FTE.NotEnoughTrucks2014 has a very good reputation on FTE.NotEnoughTrucks2014 has a very good reputation on FTE.
Quote:
All due respect to the 6, but.......
Yank it out and swap in a V8.
Old 01-21-2018, 07:59 PM
willowbilly3 willowbilly3 is offline
willowbilly3 has a great reputation on FTE.willowbilly3 has a great reputation on FTE.willowbilly3 has a great reputation on FTE.willowbilly3 has a great reputation on FTE.willowbilly3 has a great reputation on FTE.willowbilly3 has a great reputation on FTE.
It is at it's best for low end grunt in stock form. I've warmed up a couple of them for fun but the mileage goes to heck and the power band moves up so you have to rev it more. The best improvement you can make is doing a good clean up port job on the head.
For ease of tunability, I would get rid of the feedback system and put it back to 83 or earlier spec.
Old 01-22-2018, 10:07 PM
cadunkle's Avatar
cadunkle cadunkle is offline
cadunkle has a good reputation on FTE.cadunkle has a good reputation on FTE.
Quote:
I'm not ocnvinced. Looks like 120 HP and 223 ft/lbs. That's horrible, my 460 probably makes more torque at idle. Heck even my torqueless diesel probably makes more torque at idle.
Port the head, install late model split exhaust into duals or a proper header, 4v intake and Holley 600, pistons for more compression, aftermarket cam. Probably cost as much or more than building a small block. Small block costs only slightly less than building a 385 series. If you want power just find yourself a 460 and swap it in, it's a bolt in deal aside form oil filter relocation to clear the crossmember. Not worth the hassle or expense of making a tiny engine perform in a chassis that easily accommodates a proper engine.
Old 01-22-2018, 11:43 PM
I had that same set up, 390 Holley and 260 comp cam with a ZF 5 speed and 4.10 gears in a 3/4 2wd. No head porting. It really wasn't that much better than stock and never got much over 12 mpg, if ever. Plus you had to wind it another 500 rpms over a stock engine in every gear to have any torque. I drove it a lot of years but wouldn't waste my time and money to do it again. A lot of money spent for a small and questionable return. Also remember the efi duals or headers eliminate the heated manifold and that really cripples the mileage because now fuel is more likely to puddle or not atomize good in the intake. Some guys using the aluminum intake build a plate to go on the underside that circulates cooland and claim that does help the mileage issue a little. I never tried one.
Old 01-23-2018, 01:17 AM
sdiesel sdiesel is offline
sdiesel is starting off with a positive reputation.
all true what has been said. all true.
the 300 responds to careful tune and....a FISH carb!!!!
use the efi dual exhaust
the FISH has soiled britches of unwary drivers.
also, cool the oil,
also turn the cam straight up. degree it properly, rolling the retard out of it
the U turn head design is your limiting factor. a fish atomizes better thus fewer issues with irregular fueling.
play with plug heat ranges especially on 1 and 6.
truly amazing power can be had with....a turbo!! pushing air, rather than that long engine pulling air. bout 10 pounds boost please, water injection and you will scoot.get real fancy with propane at 115 octane and no more drop out....
keep everything cool
the clifford -offy -390- header-weber: is a waste of time/money/energy/and gas.
Intake question bigyellerdawg1991 Ford Inline Six, 200, 250, 4.9L / 300 3 12-13-2017 04:25 PM
240 to 300 fljab Ford Inline Six, 200, 250, 4.9L / 300 3 07-11-2016 07:32 AM
1961 f250 4x4 mountain rig build 61 F250 1961 - 1966 F-100 & Larger F-Series Trucks 14 06-22-2016 11:50 AM
carb swap or rebuild? J.Boyea518 Ford Inline Six, 200, 250, 4.9L / 300 11 05-09-2016 09:53 PM
More horse power. LIQUID8 1967 - 1972 F-100 & Larger F-Series Trucks 7 05-05-2016 04:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
