2019 FORD F-250 REGULAR CAB - ROUGH RIDING SOB - HOW TO DISABLE TPMS?
You may be able to drop tire pressures a bit without triggering the TPMS. Our truck’s factory settings are 65 psi front and 80 psi rear, but, when lightly loaded, I’ve set the tires to 55F/65R without any TPMS alerts.
When a cold snap dropped the left rear tire pressure to 63 psi, that triggered a TPMS alert.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
if you have the shock upgrade what psi do you run? Also I heard 2019 doesn't work with Forscan, have you seen it work on a 19?
I run 60/65 and am happy with that.
Dealer gave me the truck at 85 all around. Drove 1,000 miles back home before I adjusted pressure. Noticed after 500 miles or so after feeling back and neck discomfort.
Only good thing was that I am sure the suspension broke in and settled in fairly quickly.
The stock shocks Ford gives you are worthless. They have very little compression damping and rebound. Two of them were completely blown at just 12000 miles.
sarends
2017+ Super Duty
21
12-11-2017 09:02 PM
boonie
04-16-2007 07:58 PM
