KC38R-366 Dyno results
#61
I do not have a phone number. I just used email. Also, I do not have enough posts yet for private messages.
#62
I'm back.. I installed a fuel pressure gauge and WOW do I need a fuel system. Even on a daily tune It drops down to 30 psi and won't recover till my foot is less then half throttle No wonder it only made the numbers I posted and EGT's were a little warm.
I hope I didn't do to much damage to my new injectors. But for now it's in gramps tune.
So let's discuss fuel systems...I have spoke to a few vendors and fellow 7.3 people but wanted to see what's everyone is running and there experiences.
I'll put up the video of the dyno runs I made this weekend.
#63
This makes me realize I probably made the right choice going for the full irate super duty fuel system. I’m having one installed right now with 238/80 FFD, kc38r 366, adrenaline, RR plenums, RR boot kit, bellowed up pipes, a sump and harpoon mod. Should be a wholly different truck when I get it back!!!
I can’t really give you experience yet, but I think it will be best in the long run knowing the whole fuel system is up to the task.
#64
I totally agree. I thought the stock system would at least work for a bit.
Boy was I wrong. I can't wait to run this with some real fuel pressure.
Ive been told I should gain at least 60 rwhp and a bunch of torque. We will see.
What's the Irate superduty system are you running ? are you doing the basic or competition version?
#65
#66
Refresh me, where is the KC turbo made? And what place did your dyno runs? I'm on there list for a turbo but they don't want to give out phone numbers. I know they are moving. I mitt just come up and do the whole thing in Phoenix at one time. I like your numbers. Any time you get two to one on HP and Torq it's a good tune. I also believe if you do the tank mods your numbers for fuel pressure would be way better.
#67
I haven't posted a video before. I'm guessing to upload it to YouTube and post the link would be the easiest.
And her son is in a acute rehab and is doing much better.
#68
I'm still trying to come up with a plan for a fuel system. I have eliminated a few options. But looking forward to getting it going.
#69
#70
#71
#72
Can you run the dual pumps next to each other? One in the factory location and another next to it utilizing the factory harness or add a new run for the other pump? And should I consider a regulate return system at this point?
Sorry for all the questions
#73
I haven’t installed mine yet, but I’m gonna keep the fuel bowl and FRX. For the wiring, I bought the harness from Strictly Diesel, but you could just run power from the battery to a relay that’s activated by power from the 1st pump. I’m also thinking of adding a switch in the cab to disable the 2nd pump until I need it. The stock pick up will be fine for your injectors once you do the hutch mod and a pre-pump filter. I considered using a sump, but for one, they’re illegal and two, I’d have to modify my tank skid plate. As for the regulated return, I’ll see how the stock FPR does. If I have to delete the bowl a do a full regulated return, I’ll add a fuel cooler to cool the return fuel.
#74
#75
