6.7 Engine Swap Soon - Advice
#31
I believe the part number for those bolts from Ford is -W714852-S900.
#33
Right at about 0:54 of the video above illustrates what I'm talking about.
#34
Got word back from the injector and turbo shop today - the injectors all passed with flying colors. The turbo is leaking substantially out of the intake side. They agree it is probably enough to lower the oil pressure on the truck - explaining the root cause of the failure.
The exhaust side of the turbo appeared dry - is it safe to assume that the DOC and DPF are likely ok? I know if it leaks on the exhaust side it will clog the filters pretty quick, but leaking only on the intake side, i'm thinking that most or all of the oil would be burnt in combustion and hit the filters as regular soot...
#35
#36
Update - parts finally came in and it is back together and running.
Waiting on the lower rad hose to come in tomorrow before putting coolant in.
Everything seems to be working - knock on wood! The turbo is a new unit from Ford and the injectors were all cleaned and checked.
We have a few codes to work on;
P040D - EGR temperature Sensor A Circuit High
P20BC - Reductant Heater A Control Circuit High
P20C0 - Reductant Heater B Control Circuit High
P220E - NOx Sensor Heater Control Circuit Range/Performance Bank 1 Sensor 1
I'm wondering if the last three are all related to one issue - haven't really started to dig into it yet.
Also, the battery light is on on the dash, but I am getting a proper 14+ volts at the battery - so I will have to troubleshoot the signal circuit.
#38
Both trucks should be equipped with the 6R140 transmission. As far as I know, only F-450/F-550 trucks optioned with the V10 gas engines get the old 5R110W transmissions, which use the six nut torque converters.
#39
#41
Yup it is Here is a thread on it; https://www.ford-trucks.com/forums/1...ld-thread.html It is a Clark 5 speed with no overdrive and a 7.17 rear end. I've got my eyes out for the parts I need to get it into a highway gear, but it will be a good around town truck for now. I have to get a bit more work to get it back on the road but I aim to have it driving again this summer.
We are going to sell the F550 - to be honest we bought it with the bad motor just for the experience, I haven't had a 6.7 that far apart yet.
Turns out it has been an expensive experience, but since when was working on a diesel not expensive?
#42
Interesting that you would buy a 6.7 truck, just for the experience. Overall, they've been excellent for the Ford Super Duty lineup since 2011. Far less problematic than the 6.0/6.4 engines have been for Ford, which very nearly killed the Super Duty reputation and market for Ford.
Yes, diesels in this day and age are expensive. As a tech with approaching thirty years of wrenching time, I can tell you how amazing it is, there are still people out there who want a diesel because, "they are cheaper and last longer". I almost get tired of giving these guys the talk, of what buying/owning a modern diesel entails.
DocOwen
04-20-2017 09:28 PM
Wheat.
04-30-2016 01:18 AM
dirtfrmr57
08-07-2008 10:38 AM
