Oozing green blood... Spock? - Ford Truck Enthusiasts Forums
Old 01-20-2018, 03:47 PM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
BillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to behold
Ok...so I am rotating tires, cleaning battery terminals...usual minor maintenance when I see a drop on the floor towards the front. Grab the light and apparently my truck was previously owned by Mr Spock.
So... it obviously seems to be coming from the thermo housing. No biggie...new gasket and goop and she will be good to go. Maybe a new thermo while I'm at it. But .. why is it crusting up like that? Almost looks like calcification.
I assume it is having time to dry cause the leak is so slow but figured I would get a second opinion.
Thanks all!
live long and prosper.
Old 01-20-2018, 03:52 PM
Colorado350's Avatar
Colorado350
Colorado350 is online now
Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.
The GF's Commander had a slow leak too, same crusty crap on the heater hose. I cleaned it up with brake cleaner after the fix, no problem.
Old 01-20-2018, 04:44 PM
BillyBob69's Avatar
BillyBob69
Oops.... missed the picture
Old 01-20-2018, 05:15 PM
Walleye Hunter
Walleye Hunter is offline
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
Almost all liquids have some suspended (dissolved) solids in them and when they dry the solids will be left behind.
Old 01-20-2018, 05:26 PM
coax9952's Avatar
coax9952
coax9952 is offline
Athletic Supporter
coax9952 has a good reputation on FTE.coax9952 has a good reputation on FTE.coax9952 has a good reputation on FTE.
And some are corrosive......
Old 01-20-2018, 05:38 PM
BillyBob69's Avatar
BillyBob69
Yeah that’s my other worry. This had been seaping for some time but I will be cleaning this up and getting a new thermostat for it tomorrow.
Thanks for the info guys!
Old 01-20-2018, 11:02 PM
ExPACamper
ExPACamper is offline
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
Originally Posted by BillyBob69 View Post
Yeah thatís my other worry. This had been shaping for some time but I will be cleaning this up and getting a new thermostat for it tomorrow.
I'd suggest getting a new OEM housing, too. Likely the old one will have some deterioration or issues.
Also be sure to use OEM-only Tstat. It has a gasket that wraps around to the top and bottom of the Tstat. I tried the other one from Stant- couldn't seal it no matter what. OEM and done.
Good luck!
Old 01-21-2018, 12:54 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
My 2 pennies, I'd go after a billet tstat housing, too. Got one off eBay for 30 bucks
Old 01-21-2018, 07:15 AM
Dan V
Dan V is offline
Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.
If that were my ride, flush the system with distilled water, change over to an extended life coolant, new stat and a billet t-stat housing.
Old 01-21-2018, 07:17 AM
Walleye Hunter
With all due respect Dan, no ELC in a '99 unless it's had the injector cups replaced with updated sealant.
Old 01-21-2018, 10:00 AM
BillyBob69's Avatar
BillyBob69
330k on the clock ... still the original injectors and cups.
Unfortunately, no parts found locally today. So it will stay as is for now. Need it tomorrow to drive to work so...
Old 01-21-2018, 11:58 AM
timmyboy76's Avatar
timmyboy76
Walleye, mines a L99...upgraded cup sealant😉...e99 were the ******* childs
Old 01-21-2018, 12:04 PM
Walleye Hunter
Thanks for that, I thought it was all '99s
Old 01-21-2018, 12:16 PM
hydro man 17
hydro man 17 is offline
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
Gotta love those mid year changes.
Old 01-21-2018, 12:19 PM
Colorado350
So is yours an E99 or L99?
Quick Reply: Oozing green blood... Spock?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
