P0263 And P0281
Old 01-20-2018, 02:34 PM
BuddyBarnes's Avatar
BuddyBarnes
BuddyBarnes is offline
P0263 And P0281
I have been chasing a slight idle fluctuation for some time now. I ran a contribution test on AE and it comes up with p0263 Cyl 1 injector circuit contribution/ balance fault. And p0281 Cyl 7 injector circuit contribution/balance fault. Where do I need to start looking? Valve cover gaskets? TIA
Old 01-20-2018, 02:46 PM
fordpride's Avatar
fordpride
fordpride is offline
What CPS is in the truck ?
Do you have a spare CPS ?
If so change it and run your test again and see if the cylinders change.
Old 01-20-2018, 02:51 PM
BuddyBarnes
I have a ford cps about a year old. Will change and try again. I have no burned pins on valve cover gasket or harness
Old 01-20-2018, 04:05 PM
BuddyBarnes
How could a cps cause something like this? Also the 1 and 7 cyl would be on passenger side front and rear. Correct?
Old 01-20-2018, 04:45 PM
BuddyBarnes
Changed cps but engine is to cold to run another contribution test today. I will tomorrow. Buzz test is good. No other codes stored.
Old 01-20-2018, 04:48 PM
BuddyBarnes
Truck runs good just a 30 -50 rpm up and down idle.
Old 01-21-2018, 08:46 AM
BuddyBarnes
Did another test this am got 1-4-7- cyl injector circuit contribution /fault . What do i check now?
Old 01-21-2018, 01:59 PM
BuddyBarnes
Ran another test this afternoon with a hot engine and I am getting cyl 1-6-7. I am at a loss , any help would be appreciated.
Old 01-21-2018, 02:36 PM
Hussler's Avatar
Hussler
Hussler is offline
Was it the newest Ford one, Dark Gray with purple o-ring?
CPS is the heartbeat of the engine. It informs the PCM where exactly the cylinders are in rotation. Yes, odd numbers are on the passenger side.
My 97 also does that, especially when warm at idle. I just ignore it as over the years got tired of trying to figuring it out. On the 99 it's much better but different injectors and PCM coding is different, go figure.
Not a big supporter on the cylinder contribution test results. Seems like almost everyone had issues with the reported result. It doesn't mean it's not a good test for overall engine efficiency though. The fact that you flashed the PCM to 60 HP would probably make the actual test invalid. But that is just a guess on my end.
Old 01-21-2018, 03:14 PM
BuddyBarnes
Yes both cps were new ford. I also have another one coming from riffraff.
I have done some searching about the contribution test on here today and it seams that you are correct about test results not being very reliable. Yep just live with the up and down idle but I sure would like to put my finger on it. Thanks for the info.
97bamastroked
09-30-2012 03:16 PM
ampslw
04-18-2010 10:30 PM
jkidd_39
01-15-2009 10:13 AM
Dewalt17fan
21
01-22-2007 06:18 PM
elkarcher
03-26-2006 10:48 AM
Quick Reply: P0263 And P0281
