2012 F150 SuperCrew power window wiring diagram
I am in the process of trying to figure out why my power window on my passenger side front isn't working at all. I am pretty sure that I have power going to the motor but I don't know the pin diagram to the window motor and there is five wires going to the motor but I don't know which one should be hot when the switch is engaged and which ones should be a ground. I have a black wire with yellow stripe that when I ohm it out I get 0 ohms and then it goes up to 54 after a few seconds. No idea why that happens.
Red is power to operate the motor, a 30 amp circuit from fuse 1 in the body control module.
Green/violet is power to enable the motor to run. This comes from fuse 32, 15 amp in the body control module, and the fuse only has power when the accessory delay relay is closed.
Black/violet is ground for the motor
Yellow/violet is the down wire. Put voltage on this wire and the motor should move down.
Blue/grey is the up wire. Put voltage on this wire and the motor should move up.
The above wire colors are for a regular cab driver's door window. Your window in your supercrew probably has different color wires, though I hope some of them are the same, like the power wires. Your up and down wires are probably different colors but that should not matter too much.
SlabPloX
1997-2006 Expedition & Navigator
02-24-2022 01:11 PM
ron's power stroke
04-01-2007 09:20 AM
