2001 e150, i think its time for plugs? which brand? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Closed Thread
Old 01-20-2018, 01:48 PM
fabchef fabchef is offline
fabchef is starting off with a positive reputation.
hey everyone, i was thinking it might be time to change the plugs of our 2001 e150 4.6L. it has 112k miles on it and think it still has original plugs. I find at times it tends to have a shutter while driving. what do you think? i guess it cant hurt?
which brand plugs would you recommend? should i stick to motorcraft brand or any old plug will do? also, what is the recommeneded gap for the plugs? thanks
fab
Old 01-20-2018, 01:51 PM
kennyfzj80 kennyfzj80 is offline
kennyfzj80 is starting off with a positive reputation.
If you get the Motorcraft brand they are pre-gapped.
I went with the Motorcraft ones.
Old 01-20-2018, 02:42 PM
wirelessengineer wirelessengineer is offline
wirelessengineer is starting off with a positive reputation.
Yeah, just go with the basics.
Pre-gapped or not, check them yourself. Boxes can be dropped, gaps can be changed.
Whatever you do, don't fall for the "split fire", "E3", or other gimmicks.
https://duckduckgo.com/?q=gimmick+sp...&t=ffnt&ia=web
Old 01-20-2018, 03:12 PM
CWR032 CWR032 is offline
CWR032 is starting off with a positive reputation.
I tried the Split Fire, they did seem to improve the bottom end a little, but they were crazy expensive and didn't last 5,000 miles.
I also recommend checking the plug gap with a proper feeler gauge, not the round gapper. The last pregapped plugs I bought were off several thou. You should visually check each plug before you pay for them as I've been handed one that was dropped, the ground electrode was crushed into the center electrode and the insulation around it was cracked.
Old 01-20-2018, 04:41 PM
vettex2 vettex2 is offline
Temporarily Deactivated
vettex2 has a good reputation on FTE.vettex2 has a good reputation on FTE.
split fire's are snake oil, they just empty your wallet
as long as you use the proper plug, spark plugs do not affect power or milage
use the wrong plug and both can suffer
pre-gapped plugs have a coating that can come off when you use a feeler gauge
Quote:
"Seems to" and various dyno tests disagree. The dyno says they do nothing. There have been a number of articles in various car mags over the years where they've been tested scientifically. Nobody has found any benefit.
Quote:
it's called the placebo effect
my old team dynoed just about every brand of plug with the same result
all I'll add is don't buy champions
Old 01-20-2018, 07:29 PM
Im50fast's Avatar
Im50fast Im50fast is offline
Nice guy!
Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.
The gap isnít such a big deal to be accurate. My plugs had 320,000 miles on them when I removed them. The gaps were over .100 (yeah I typed that correctly )
come to to find out it had a bad coil. The plugs probably could have gone even longer.
Im not advocating for 300,000 mile change intervals. Iím just saying the gap isnít that important. Make sure it ainít touching. Eyeball it. Get her done.
Old 01-21-2018, 04:01 PM
jeffreyclay jeffreyclay is online now
jeffreyclay is starting off with a positive reputation.
I can't believe what I just read. Wrong on so many levels.
Old 01-21-2018, 06:25 PM
LMAO !!!
Old 01-21-2018, 07:12 PM
wiskeyVI wiskeyVI is offline
wiskeyVI is starting off with a positive reputation.
That's great!
Old 01-21-2018, 08:16 PM
Im50fast's Avatar
Nice guy!
Canít argue with the facts boys.
Old 01-22-2018, 07:48 AM
A little knowledge is a dangerous thing, and it's clear you have a little knowledge.
Old 01-22-2018, 04:35 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
I'll add this, seems nobody else did: Be prepared to have one or more of the old plugs take out the threads in the heads when they're removed. And be prepared to helicoil those to fix them. At that age, it's bound to happen with the mod motors. If somehow none do, buy a can of thread lube to use to insure it never happens in the future.
Old 01-22-2018, 05:05 PM
Quote:
Originally Posted by Im50fast View Post
Can’t argue with the facts boys.
but you have a tendency to believe in "alternate facts"
you are right about the plugs though
I can't remember his name but the guy who had a fleet of vans confirmed this
was his name Del Griffin?
Closed Thread
Need help - hard starting in middle of cross country trip! jgrohs54 1999 - 2003 7.3L Power Stroke Diesel 22 07-19-2017 10:36 AM
Replaced plugs in 07 F150 5.4 nightmare FordTruckFan01 Modular V8 (4.6L, 5.4L) 1 06-21-2017 11:00 AM
Truck not running need help Jonnylightning 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 06-08-2017 08:32 PM
COP boots Donebrokeit Modular V10 (6.8l) 4 04-28-2016 08:32 AM
1994 f150 4.9L 300 - Performance spark plug wires vs. regular spark plug wires? ElizabethRanee 1987 - 1996 F150 & Larger F-Series Trucks 1 04-09-2016 06:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
