Wheel Bearing/Hub Assembly Question
Hi All,
My 2014 F250 w/ 100k miles is starting to have some serious rotational noise between 0-40mph. I had a hunch it was the wheel bearing but had a local shop confirm this morning. They want $700-$750 for the job. On ebay I can pick the part up between $200-$400 depending on the brand.
2 questions for you guys..
#1) Is there a certain brand you recommend? MOOG? Timken? OEM (If I can find it..)?
#2) How hard is this job? I'm thinking a buddy and I can knock it out in an afternoon but just want to hear if anyone on here has experience with this..
Thanks!
Sean
Thanks!
Sean
I personally always went with Timken, Auto normally sticks them and the ones I bought had a 3 year no questions asked warranty.
I would say you easily should be about to get it done in 2 - 2 1/2 hrs for your first time. I ran a snowplow so got quite good at changing mine. Had it down to about 40 mins a side.
Not much to it. Take the wheel off, manual hub off, snap rings inside hub, along with plastic spacer washers(pay attention to how they are arranged, take off caliper, rotor and pads. Then four bolts from the back and out it comes. Clean up any rust, replace any seals behind it if needed, I always put a little anti seize on the mating surface to help with down the road repairs and reinstall in reverse order.
Get some good snap ring pliers...the snap ring around the axle shaft is pretty robust. Before putting new hub assembly on truck...take a good look at the knuckle assembly where wheel bearing slides into. Any rust/deformation on that lip where the o ring seals.....take some fine sand paper and remove that, otherwise you can damage the o ring and your esof won't work properly.
MoyockPowerstroke
04-09-2010 01:47 PM
