Delivery Time & COTUS - F350?
#31
again can you tell me what you did on Etis?
I go to “vehicle” and then enter the VIN. It gives a vague description of the truck but nothing else and nothing has changed for weeks. Supposedly my build date was 2/10-2/17 which means it should have finished 3 days ago. Is there something else to do after you enter the VIN— or click to a specific site on Etis?
#32
Create a free user account in ETIS and log in. Click on vehicle lookup and enter VIN. Information shown under "Primary features" will be very basic with a generic build date that doesn't make sense. a few days after it is built, build date will display as MM.DD.YYYY or 16.02.2018 for February 16, 2018. After it is built, minor features will also display all features built into your truck. Have you received a window sticker? If not, copy this link and add your vin at the end: http://www.windowsticker.forddirect....icker.pdf?vin= At the bottom of the window sticker will be a date. My build date was 8 days after the date listed on the window sticker, and details showed in ETIS about 10-11 days after the sticker date. Hope that helps.
Its DD-MM-YYYY
#33
#35
Same her, my Sticker and order say crew...ETIS says double cab. Sounds like a common mix-up in ETIS, although I haven't heard of anyone who had a SuperCab delivered instead of a crew their dealer ordered.
#36
Create a free user account in ETIS and log in. Click on vehicle lookup and enter VIN. Information shown under "Primary features" will be very basic with a generic build date that doesn't make sense. a few days after it is built, build date will display as DD.MM.YYYY or 16.02.2018 for February 16, 2018. After it is built, minor features will also display all features built into your truck. Have you received a window sticker? If not, copy this link and add your vin at the end: http://www.windowsticker.forddirect....icker.pdf?vin= At the bottom of the window sticker will be a date. My build date was 8 days after the date listed on the window sticker, and details showed in ETIS about 10-11 days after the sticker date. Hope that helps.
#39
#40
#41
Congrats on the new truck order!
#42
thankx. I see your in the Bay Area. I have a former colleague In studies there now and tells me I need to come visit. Any advice on boondocking and or a RV site when I’m there.
#43
I've heard there are some great options down in Monterey, or up the coast a little bit north of Marin.
Good luck and if you find any neat spots, let me know!
#44
Good question! We are brand new to RV'ing and are actually about a month away from thing delivery of our first fifth wheel.
#45
will do. Congratulations on the fiver. What you get. My wife an currently have a 2015 Open Range 311FLR. (GWR of 11900) and the ability to carry almost 1.5 ton of cargo. We Just love it. Perfect for an older couple. (No kids basically lol) Best of all it it gives you the option to haul via gooseneck or traditional fifth wheel. And it doesn’t void any warranty. That’s how I currently haul it as it frees the bed in 30 sec and I only have to lift the 3lb ball.
I've been going back and forth between a couple of hitches. A traditional B&W Companion slider, an Andersen Ultimate Hitch, or the Reese Goosebox. All have their pros and cons. The Goosebox is probably the simplest, but with the shortbed, it could cause the nose to get uncomfortably close to the cab. I would love to have only the ball in the bed though!
