Trailer hitch pin size
Thanks for that. Just ordered one to replace my current. The fewer keys I have to keep up with the better.
Received 6,629 Likes
on
Yes it will use that key. Read the direction twice because you only have one time the set it. They have been having pins getting bent using the reducers. It might take out the slack in the receiver but when you have a heavy load with a 2" hitch with reducers from 3" your only pulling in the middle of that pin causing it to bend
How heavy is too heavy? (I have a F450 on order that will have a 3" receiver. I pull 2 different 12,000# trailer (1 dead weight, 1 weight distribution, with 2" hitches.) I'd rather not buy new hitches!
Any pins that can handle the job without bending?
on
First Dually, I can't find anything in the owners manual or the towing guide to back this but but the max towing capacity is only when using a 3" shank ball mount. When a reducer is used the capacity is also reduced. I thought I read it somewhere but I can't find it now. Maybe it was just something someone posted. Maybe it will be printed on the truck's hitch.
I chose to buy a WDH with a 3" shank as well as a regular non-WDH ball mount with a 3" shank. Now I don't have to worry about carrying around the reducers.
I seen them use those pins from farm supply with the handle but they don't lock. I would think it's more from jamming brakes putting a shock on it on hard stops than pulling as you ease into a pull.
If I had 2" hitches that I do not want to replace because I now have a 3" receiver I would do the following. I would find a 3" sleeve to fit over the 2" hitch. Get it fitted and hole lined up and test fitted on truck. I would not tack weld it because I don't want to ruin any temper with heat. I would fill the walls of the hitch to sleeve with J-B Weld and assemble it let it dry. It will not slip and would work the pin just as a 3" hitch. You would still only have only the capacity of the original 2" shank. No more bent pins or sleeves to deal with.
