1970 f250 defroster duct? - Ford Truck Enthusiasts Forums
Old 01-19-2018, 06:27 PM
Thipdar's Avatar
Thipdar Thipdar is online now
Thipdar has a good reputation on FTE.Thipdar has a good reputation on FTE.
Looking for an aftermarket replacement/reproduction for a C7TZ-18A637-A (the left side). I'm guessing that NOS parts are scarcer than moon rocks.
Clardy was kind enough to squish mine flat when they installed the aftermarket A/C, and it didn't come out intact when I dropped the A/C to get access inside the dash.
I need the defroster/defogger more than I need the air conditioning, so the A/C may come out entirely.
Old 01-19-2018, 06:47 PM
DisneysPatB DisneysPatB is offline
DisneysPatB is starting off with a positive reputation.
Dorman #96003 2 1/4", 96004 2 1/2", 96006 3"
Gates #23836 2 1/4"
Old 01-19-2018, 08:24 PM
Thipdar's Avatar
Quote:
Gates #23836 2 1/4"
The OE is 2.25", would have to fashion something to make the ends work.
Thanks.
Old 01-19-2018, 08:57 PM
Last time I checked 2.25 = 2 1/4 inch. I found mine on ebay for 32 for a pair.
Old 01-19-2018, 08:58 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1970 F250 defroster duct
Quote:
Invalid part number.
2) C7TZ-18A636-A .. Right & Left Windshield Defroster Nozzle & Connector ~ Not used with 1968/72 F100/350 w/factory installed integral A/C / Obsolete
1967/69 F100/1000 & N/NT500/1000 with deluxe heater; 1970/72 F100/750.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
KAMA OBSOLETE PARTS in East Bethel MN has 2 = 763-434-0123.
Old 01-22-2018, 02:55 AM
Thipdar's Avatar
Hi, Bill:
Take a look at this illustration:
If you look carefully, you'll see that the lower half of the left-hand hose is pointed to by two arrows... it's designated as both "18A636-A" and "18A637-A". The lower half of the right-hand hose has no arrow pointing to it. I'd think the actual information is fairly obvious... but whether that error has propagated into other areas of the system, I can't tell.
I've picked up some 2 & 1/4 inch ducting and am going to improvise.
BTW, my truck does not have the integral air conditioning, it has a Clardy add-on. When the Clardy was installed, they squished the original ducting flat. Hopefully, I'll be able to re-route the replacement ducting to avoid that problem.
Old 01-22-2018, 02:57 AM
Thipdar's Avatar
It depends on how many decimal places you round off to
Old 01-22-2018, 07:19 AM
mrpotatohead mrpotatohead is online now
mrpotatohead is gaining momentum as a positive member of FTE.
That must be some of that "new" math.
Old 01-22-2018, 07:21 AM
Hi, Bill:
I don't see the "A" suffix on either part #. My guess is the only difference between the two parts is the length. I've installed many of these and the old ones were slightly crushed from the factory as it has to snake around the radio and ash tray.
Old 01-22-2018, 12:37 PM
Thipdar's Avatar
Quote:
Yup, you are right. There aren't many parts in that illustration designated as "-A". Quoting "-A" when it isn't there was an excess on my part. The reason I brought it up is because if "18A637" is shown on the drawing, then it ought to link to a valid part number. Also, it's pretty obvious to me that the "18A636" part is still installed in my truck, so I don't need it.
Different lengths would seem to be a rational reason for different numbers. I can see where the longer part might supersede the shorter, in order to reduce the number of parts needed in inventory; it would probably work in either position.
Old 01-22-2018, 02:28 PM
Hi, Bill: Take a look at this illustration:
I don't need to look at it, because I know better...this is a generic illustration for ALL 1965/72 truck heaters, but they're not all the same.
Here are the applications for the ducts: Do you see C7TZ-18A637-A? No you don't and I don't either, as there's no such thing.
Old 01-22-2018, 05:41 PM
Thipdar's Avatar
I don't need to look at it, because I know better...this is a generic illustration for ALL 1965/72 truck heaters...[/IMG]
I'd agree with you, except that the illustration doesn't indicate "Typical".
Old 01-22-2018, 05:56 PM
Parts catalog doesn't say typical, but for us (JEFFFAFA and I) in the know...we know better.
Look at the applications I posted for the ducts. If that doesn't convince you, I don't know what will.
Old 01-22-2018, 06:20 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is offline
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
When I needed both ducts for my 68 F250 (without factory A/C) I used some 1st Gen Mustang ones
Brand:Scott Drake
Manufacturer's Part Number:C5ZZ-18490-K
Old 01-22-2018, 06:22 PM
JEFFFAFA's Avatar
2X. It is true. Some pics were pretty true to the vehicle. But not all.
E-350 rear defrost comes out hot when front temperautre is set to cold Trevor Clark Cooling, Heating, Ventilation & A/C 2 01-30-2018 01:49 PM
A/C only blows defrost and floor no dash sschaffner 2007 - 2014 Expedition & Navigator 2 12-11-2017 07:36 AM
A/C Compressor squeal david772 1999 to 2016 Super Duty 18 11-16-2017 07:11 PM
A/C vent/floor/defrost question azul_grande 1973 - 1979 F-100 & Larger F-Series Trucks 9 06-15-2017 10:58 AM
A/C and heat not working THEDON117 1999 - 2003 7.3L Power Stroke Diesel 12 10-02-2016 03:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
