how do i pull codes for a 95 f-150? - Ford Truck Enthusiasts Forums
Old 01-19-2018, 01:07 PM
dreamofford
dreamofford is offline
dreamofford is starting off with a positive reputation.
i have a code reader but no instuctions with it. i plugged it in and it gave me a bunch of numbers that don't make sense.
Old 01-19-2018, 01:16 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
It is difficult to say without knowing what scan tool you have. I'm guessing it is the 3145 Equus Innova since it has a number display and not a flashing light.
https://www.amazon.com/INNOVA-3145-Ford-Digital-Reader/dp/B000EW0KHW
Old 01-19-2018, 01:17 PM
TexasGuy001
Old 01-19-2018, 02:03 PM
sandymane's Avatar
sandymane
sandymane is online now
sandymane is gaining momentum as a positive member of FTE.sandymane is gaining momentum as a positive member of FTE.
I have noticed you have posted several questions that could have been easily answered in the Haynes Manual available online or at most parts stores. I was in the same boat as you about a year ago with my 95. I got the book and when I get help here the book goes into detail about a lot of the information I get and it helped me. I still get plenty of the help I need here and follow up with my book to complete the task. You will get all the help you need here but the manual will help you even further and sometimes the pictures help also. Just trying to relieve some frustration I know you are experiencing. Good luck and enjoy working on the truck. Sandy
Old 01-19-2018, 02:19 PM
yellercat's Avatar
yellercat
yellercat is offline
yellercat is starting off with a positive reputation.
So guys, is this the code reader you would recommend?
Old 01-19-2018, 02:45 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
what does it do?
Old 01-19-2018, 02:59 PM
McLeod's Avatar
McLeod
McLeod is offline
McLeod has a good reputation on FTE.McLeod has a good reputation on FTE.
I just count the check engine light to retrieve codes = FREE
A '95 will be three digit codes.
Old 01-19-2018, 03:10 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
man i hate counting.
Old 01-19-2018, 03:12 PM
McLeod's Avatar
McLeod
McLeod is offline
I see someone had printed off info from the old fordfuelinjection site.
2 and 3 digit codes included:
https://www.scribd.com/doc/34996350/...-and-Procedure
Old 01-20-2018, 11:48 AM
dreamofford
how to read code
the reader i got no numbers just a flashing light so it is not much better than a jumper wire. i plane on getting a haynes manual or better yet a real shop manual. and some fuel line disconnect tools and learn how to use them.
Old 01-20-2018, 02:35 PM
sandymane's Avatar
sandymane
Get the disconnect plastic ones in the set. Metal ones don't work as well I have heard. The plastic worked great for me. You can order a ford manual on CD from Ebay but the book you can carry to the truck. Sandy
Bluebomber94
11-11-2017 10:20 PM
Keljoe
09-11-2017 02:41 PM
Blakshukvw
08-03-2017 05:45 PM
i eat hybrids
05-20-2017 10:15 PM
RustyTrustyF150
1997 - 2003 F150
04-21-2017 09:53 PM
Quick Reply: how do i pull codes for a 95 f-150?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
