Power loss and rough idle.
1999 7.3. First starting the truck it runs and idles great. But only after a few minutes of driving it’s starts to lose power and bog down. It will go away after a few seconds of increasing the RPMs but then idles rough and happens again. Hasn’t died yet. Buddy says it might be a bad CPS. Also I’m noticing when this happens my RPMs will get stuck around 11-1200 RPMs and then drop way down to about 500 The truck always idled at about 750 800. Any ideas?
Sounds like a possible fuel delivery problem. Theoretically the fuel bowl will be full by the time you try to start but if the pump is weak or there are issues with the in-tank screens it will eventually starve out. The main lump in the gravy here is it will clear up when you rev up the engine. Is this under load or sitting?
No it’s not on 1/4 it has an 88 gallon tank. I don’t ever let it get below 1/2
When it’s under load
david5
05-31-2016 12:41 PM
kbarbee95
19
10-02-2014 10:32 AM
Coolbean1000
03-12-2014 08:59 PM
Glsimmons123
12-01-2012 12:15 AM
nutfarmii
20
10-15-2008 06:17 AM
