Just another headlight upgrade question - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 01-19-2018, 09:56 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
BillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to behold
I have been checking other threads and something I noticed is that depending on the year, you can get either 2 piece or one piece each side.
I am looking at this for my E99.
Currently I have the factory dull lights that are 2 pieces each side.
I would like to upgrade to the 1 piece each side with the clear lense for more light. HOWEVER... I don't want to go chopping into the header panel for fit.
So... Is there an option?
I don't need to go with HID and Halo lights or projection beams... I just would like to use my SilverStars in a clear lense housing that is 1 piece each side.
Possible?
Thanks all!
Old 01-19-2018, 10:33 AM
Colorado350's Avatar
Colorado350
Colorado350 is online now
Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.
So you have sealed beams now and want to convert to the light housing that uses a bulb? If that's the case yes you can.
Old 01-19-2018, 10:42 AM
BillyBob69's Avatar
BillyBob69
Nope...I have this now....
Would like something like this.....
Not specifically that model..but the clearer lens. Also all one piece.... or is that a pipe dream?
Old 01-19-2018, 11:02 AM
Dan V
Dan V is online now
Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.
I'm not sure about a 1 piece that isn't based on the 2005+.
I went with something similar to these.
Clear Corners
With something similar to these.
2002 Headlight Clear
Old 01-19-2018, 11:07 AM
Dan V
Dan V is online now
Old 01-19-2018, 11:10 AM
BillyBob69's Avatar
BillyBob69
Originally Posted by Dan V View Post
Yeah I have run those before but they just didn't seem to fit well together. Could of been a cheap or badly made version... then a ladder fell and the end hit the corner and broke it so I went back to OEM. Want to upgrade to something better now.
Old 01-19-2018, 11:29 AM
Colorado350
I removed the Ford upgrade for the 99+ with clear lense, I gave them to JSTIHL. I swapped them for Trucklites LED's.
Old 01-19-2018, 11:57 AM
BillyBob69's Avatar
BillyBob69
Anyone ever use these?
HEADLIGHTS
EDIT: Nevermind...they are 2 piece.
Old 01-19-2018, 02:25 PM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.
Billy bob - Mine are worse than yours & Im getting tired of sanding them with deet. Ive scrubbed them so many times they are worse now than when I started about 5 years back. Def following this thread.
Old 01-19-2018, 02:29 PM
BillyBob69's Avatar
BillyBob69
That pic was just used for reference. I did mine again about 2 months ago and they are so so now, but really want new.
Old 01-19-2018, 02:43 PM
guitarpicr's Avatar
guitarpicr
Was just looking ay Spyder headlights. They have a set that are one piece & look like the 2005-2007 & says they fit the older models. Im gonna call & talk to them. Be back.
Old 01-19-2018, 02:54 PM
guitarpicr's Avatar
guitarpicr
I called them about these lights & rep said the only modification was to the factory wiring for high/low beams. They dont post the installation instructions online unfortunately. She said the kit includes the instructions specific to each vehicle, so not too sure what all will be involved. Item # 284597645 -
Old 01-19-2018, 06:26 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
I was looking fur them also. Don't want v to hack the heder up. Found a ton of them on eBay, but who knows how the fit/finish is
Old 01-19-2018, 07:30 PM
Colorado350
Here's the link to the Trucklites: Truck-Lite (27450C) Headlamp
Amazon Amazon
This isn't my video but it's the one I watched that made me realize that I could put these in my truck. As mentioned in the video if you have sealed beams these just replace the sealed beams. If you have the other option, like I did it's a bit more involved but IMO worth the work. F you google Trucklites or go to YouTube you can see the difference...
Old 01-21-2018, 12:02 PM
BillyBob69's Avatar
BillyBob69
Hmmmm. I like the idea of the LEDs... but not sure I am sold on the look of the sealed beam style. I see those styles going down the road but it just doesn’t seem right to me. LEDs tho... definitely. But only if replacement is easy. See ... I want my cake and eat it too!
Quick Reply: Just another headlight upgrade question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
