Is it in 4wd or not? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-19-2018, 07:17 AM
chaser1602
chaser1602 is offline
chaser1602 is starting off with a positive reputation.
I have an 04 f350 d 4x4 with the esof. Pass side hub is leaking air, not holding vacuum when the 4wd switch is put in 4wd. I know this because I tested it with a vacuum pump. My hubs have a auto and lock setting. When I turn the hubs to lock is that manually putting the hubs in 4wd ? I tried that and it didn't feel like the truck was in 4wd. And the 4wd switch in the dash was switched to 4wd
Old 01-19-2018, 09:24 AM
seville009
seville009 is offline
seville009 is gaining momentum as a positive member of FTE.
Yes - if youíve manually locked the hubs and have engaged the 4wd in the cab, then you should have 4wd. Thatís why you have the option to manually lock them, in case the vacuum system dies.
Can test if itís in 4wd by msking a tight turn and feeling if the steering binds up a bit.
Old 01-19-2018, 09:35 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
common pproblem on 4H, 4L selector is the selector **** itself.
it develops cracks on the plastic that results in the **** just spinning.
so make sure the indicator light changes correctly as you select. if not, check the plastic ****.
Old 01-19-2018, 10:24 AM
RailDawg
RailDawg is offline
RailDawg is starting off with a positive reputation.
Until I can find out why I’m not getting vacuum to my hubs I’ve left my auto-locking hubs in lock.
I’ve been told it doesn’t really hurt anything.
When I turn the switch on the dash is when it actually goes into 4wd.
Old 01-19-2018, 10:44 AM
seville009
Originally Posted by RailDawg View Post
Until I can find out why Iím not getting vacuum to my hubs Iíve left my auto-locking hubs in lock.
Iíve been told it doesnít really hurt anything.
Wonít hurt anything.....I manually lock my hubs for the whole winter esch year.
Old 01-19-2018, 10:28 PM
maticuno's Avatar
maticuno
maticuno is offline
maticuno is gaining momentum as a positive member of FTE.maticuno is gaining momentum as a positive member of FTE.
Stop on a dirt road. Floor it. If your rears spin and it takes a few to get moving, you're not in 4H. If you immediately launch forward, you're in 4H.
Old 01-19-2018, 11:51 PM
Lawnpro979's Avatar
Lawnpro979
Lawnpro979 is offline
Lawnpro979 is starting off with a positive reputation.
With truck NOT running, Lock the hub, then try to turn the shaft, by hand
this will tell you if it’s engaging or not
Old 01-20-2018, 03:13 AM
seville009
this will tell you if itís engaging or not
Thatíll just tell you if the hubs are locked, not if the transfer case has engaged.
Old 01-20-2018, 08:11 AM
Lawnpro979's Avatar
Lawnpro979
Ahhhh, ok thanks, tht makes sense....
Old 01-24-2018, 10:46 AM
chaser1602
The **** is fine. it turns the switch. Turns to 4h 4l and off. I can here the motor turning on/off
Old 01-24-2018, 10:50 AM
chaser1602
I tried that on snow. Didn't feel like it was in 4wd at all. That's the reason of my original post.
Old 01-24-2018, 11:50 AM
twigsV10's Avatar
twigsV10
twigsV10 is offline
twigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud oftwigsV10 has much to be proud of
Put it in 4wd and see if you can turn the front driveshaft by hand. If you can't, jack the front wheels/wheel up and try again, if you still can't it's likely the lock out hub is broken.
If the front driveshaft turns with wheels jacked up it is the transfer case.
Old 01-24-2018, 07:09 PM
00t444e's Avatar
00t444e
00t444e is online now
00t444e is gaining momentum as a positive member of FTE.
You don't even have to jack it up. Put it in 2wd and lock both hubs then try to turn the front driveshaft by hand it should be locked if not then one of your hubs isn't engaging. Then if both hubs are working unlock the hubs and shift into 4x4 and try to turn the front drive shaft if it turns then the transfer case isn't engaging.
254XP3
12-13-2017 08:14 AM
rock2610d
06-04-2017 04:39 PM
Gerryb48
03-26-2017 03:44 AM
Skrogers
07-12-2016 07:49 AM
Quick Reply: Is it in 4wd or not?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
