Aerostar Ford Aerostar
High idle on my 93 4.0L
Old 01-19-2018, 05:44 AM
DET17's Avatar
DET17
DET17 is offline
Wondering if the beast is missing a temp sensor input, believes itself cold.
After a 10 minute drive I'm still idling around 1800rpm. Sometimes a "kick down" like the old carb days, will bring the idle back to around 1000.
Curious if this is another 4.0L failure mode.... most likely suspect? TB was cleaned several years ago, but has never been removed AFAIK.
Thanks folks.
Old 01-19-2018, 10:47 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
Look for a vacuum leak first.
Run a self test on the EEC to see if it's captured any error codes.
Old 01-21-2018, 05:23 PM
Jose A.'s Avatar
Jose A.
Jose A. is offline
make sure the air tube from the air filter box to the intake is not torn or leaking at either end. Remove it and inspect it for tears.
If torn, repair with a flexible gasket maker.
Old 01-24-2018, 06:42 PM
DET17's Avatar
DET17
DET17 is offline
Believe it or not, I've never pulled codes from this Van in 24 years! Found the EEC plug, Youtubed the jumper pin position, warmed it up completely and.....
No codes. Neither KOEO nor KOER produced so much as a BLINK in my system display! My Aero has the digital dash, so the bottom line of this LH display area is the CHECK ENGINE. I can't even get it to blink a 3 count for 6 cylinders..... as the Youtube videos show. Zip, zero, zilch, nada.
Finding a vacuum leak is going to be a joy, if that's all that is left.
Old 01-25-2018, 02:18 AM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
Don't forget the IAC mounted on the side of the throttle body. They gum up from dirt and EGR junke, also mechanical wear item.
Unplug the wires to the IAC, check for idle change. Ran by PCM with a PWM high speed data signal
Some have luck cleaning, most don't
Old 01-25-2018, 06:55 PM
DET17's Avatar
DET17
DET17 is offline
Yes sir, I knew the IAC was a suspect, wherever it was! I'll test it... no doubt, an IAC stuck open (or randomly open) would cause the high idle. I'll report back my findings.... thanks or the tip.
evan_nugget
03-22-2018 07:11 PM
F-250Flyer
09-15-2017 07:46 AM
joedangelo04
02-12-2017 02:08 PM
92eddiebauer
1978 - 1996 Big Bronco
12-14-2009 12:18 AM
fordbroncodave
08-03-2009 08:50 AM
Quick Reply: High idle on my 93 4.0L
