Oil leak in the front
This is a steady drip while parked and increases to a spray when driving. I cleaned up the fittings at the bottom of the transmission cooler to check for leaks and took these pics. Is that connection to the transmission cooler always that way - pieces of tubing patched together? Should I be replacing that whole tubing coming from the cooler? What else to look for?
No clue.
Looks like someone added a 6.0 cooler and used 3/8 copper line to 1/2 rubber.
You need 1/2 line from the cooler, then a 3/8-1/2 barb adapter to connect to the OEM cooler line
Also you might want to hunt down the other joint for the cooler as its probably the same rig.
PS: If that is how your mechanic does work, you might want to find another. Did you know that that leak can cause a fire. ATF burns real well at 70 MPH
Thanks to everyone on the FTE for pointing these out and enabling us !
