OT - battery charger recommendations
I have a general shop question for the group.
What do you all recommend for a shop battery charger? I have an old Christie battery charger that works like a champ but is a bit overkill. Years ago I had to modify the diode stack in it and since then it really puts out the jolts and if you're not careful you can cook a battery.
I'm looking for a decent automatic battery charger for car and motorcycle batteries that can put out enough oomph to boost a car if necessary.
Thanks
Bobby
Thanks
Bobby
The best true float charger I have is the 3 amp Battery Tender. I bought this version from Costco for $30; it will charge to full capacity and then keep the charge without overcharging.
As previously stated, Schumacher is another quality brand; I have wheeled model with 10 amp for charging and 40/200 amp for engine start. It is a 40-year-old model that does not have the circuitry for automatic shutoff; it uses a dial timer.
I also have a Chicago (Harbor Freight) 2/6 amp charger that has automatic shutoff. It does the job but connections have to be tight otherwise the meter bounces up and down. Cost wise, the Chicago is the best choice for occasional use but like most Chinese electrical products, quality control is lacking.
Everything you ever wanted to know about charging lead acid batteries from Battery University.
Charging Information For Lead Acid Batteries ? Battery University
Warning: You might saturate your brain reading this but there is lots of good info here.
Philip
Philip
I've heard good things about the Battery Tender and the Schumacher brands.
My old Christie is a wheeled unit and I think I'll try to find something smaller.
I have several "trickle" chargers that use for the jetskis, motorcycle, etc but I think I want something similar to what Bob posted.
Thanks everyone for your opinions and experience. I'll start looking around and pricing things.
Bobby
Bobby
Thanks
Bobby
Thanks
Bobby
Thanks
Bobby
Thanks
Bobby
I am glad you corrected me. But my message is the same, if you are going to buy a charger get one with the AGM, absorbed glass mat setting and then if you purchase a AGM battery in the future you are set. The number one killer of AGM batteries is overcharging.
B
