Putting truck in 4WD then shutting it off - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 01-18-2018, 08:07 PM
marobrown
marobrown is offline
marobrown is starting off with a positive reputation.
My driveway is a pretty steep grade, 2 cars deep out to the street, dash shows itís an 8 degree slope. My old truck actually slid out of the driveway on several occasions in the snow. I came home from vacation last week to a light dusting, turned on my r wheel drive and backed in, 2 tires in a bare spot where my daughter parked, 2 in the snow. I left it in 4X4 so I had a little extra holding it in place with the front axle locked in. Made me wonder the next day, with auto hubs does the 4WD stay engaged after turning off the truck and vacuum is gone?
Old 01-18-2018, 08:10 PM
eberlestock's Avatar
eberlestock
eberlestock is online now
eberlestock has a good reputation on FTE.eberlestock has a good reputation on FTE.
yes it will stay engaged. Even after you take it out of 4 wheel drive it takes a bit before the hubs unlock.
Old 01-18-2018, 08:14 PM
K A M
K A M is offline
K A M is starting off with a positive reputation.
You can leave the hubs in lock to make sure. Then just used the switch to lock up the transfer case in and out as needed until the thaw
Old 01-18-2018, 08:50 PM
Buliwyf
Buliwyf is offline
Buliwyf is gaining momentum as a positive member of FTE.Buliwyf is gaining momentum as a positive member of FTE.
Just don't park a car next to it.
In 2wd it'll slide on the ice straight down, but at work, if parked in 4wd, the trucks would turn a little and hit each other.
Old 01-18-2018, 09:20 PM
marobrown
will leaving the hubs locked cause binding during turns?
Old 01-18-2018, 09:26 PM
00t444e's Avatar
00t444e
00t444e is online now
00t444e is gaining momentum as a positive member of FTE.
If you are in 2wd no, I have manual hubs and I leave them locked all winter and just shift in and out of 4x4 when I need to.
Old 01-19-2018, 07:40 AM
K A M
K A M is offline
Only when in 4X4 will it bind on a hard surface with no tire slippage. Just remember to take it out of 4X4 when you get on the highway. Also when in 4X4 you really only have one front wheel and one rear wheel holding when in park. If you put your parking brakes on that will hold both rear wheels
Old 01-19-2018, 09:06 AM
00t444e's Avatar
00t444e
No even if you have open differentials when the drive shaft is locked one wheel can't spin without the other wheel spinning in the opposite direction. When parked in 4x4 all 4 tires are holding.
Old 01-19-2018, 09:16 AM
acadianbob's Avatar
acadianbob
acadianbob is offline
acadianbob is gaining momentum as a positive member of FTE.acadianbob is gaining momentum as a positive member of FTE.
THAT is good to know. Never would have thought of that.
aircargoo
1997-2006 Expedition & Navigator
03-26-2017 07:58 AM
Bordeauxman
1999 to 2016 Super Duty
03-13-2017 05:25 PM
Bt-99
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
12-20-2016 02:44 AM
mark227
12-17-2016 03:54 PM
Sunstreak
05-11-2016 05:11 PM
Quick Reply: Putting truck in 4WD then shutting it off
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
