Hpop and fuel bowl reseal no start
So I'm at a tand still and I've seen so many threads I just wanna hear what you guys know.
I have a 2002 f350 7.3l turbo diesel. I recently just did a hpop and fuel bowl reseal. Job went well got it all back together and what do you know, it wouldn' start. It cranked but didn't start. In the process of removing I took all 4 lines off the fuel bowl and the 2 bolts holding it in place. Then moved to the hpop. Both oil lines removed and the bolt with the black washer that holds it in place. I tool the ipr valve off and the 2 oil line valves off the replace all the gaskets. I removed a bolt that allowed oil to drain to empty it out and clean it up. I didn't touch the non serviceble plug. I' at a stand still. I'e checked all connections. Clean and snug. Oil is full as well as in the hpop res. I' getting pressure in the fuel bowl. Injectors won't fire. I need help 😣
