Exhaust Brake - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Exhaust Brake
Old 01-18-2018, 03:51 PM
UpInSm0kE
UpInSm0kE is offline
UpInSm0kE is starting off with a positive reputation.
Exhaust Brake
Sorry if this has been covered before, Is it recommended by Ford to run the Exhaust Brake at all times except during icy,snowy conditions. I am coming from a 2015 Ram 6.7 and Cummins recommended running it all the time to keep the turbo vanes from gumming up.
Old 01-18-2018, 04:11 PM
Martin6
Martin6 is offline
Martin6 is starting off with a positive reputation.
I don't know if it's a Ford recommendation, but I run mine on all the time when conditions are acceptable.
Old 01-18-2018, 04:20 PM
UpInSm0kE
I loved the feel of the Exhaust brake on "Full" in the Cummins. The Ford is way different as you cant really hear/feel it engaging like the Cummins. The Ford really downshifts in the trans like it is in tow/haul when the exhaust brake is engaged in full. Is this normal behavior for the Power Stroke?
Old 01-18-2018, 04:30 PM
stewy604's Avatar
stewy604
stewy604 is offline
stewy604 is starting off with a positive reputation.
I use mine about 50% of the time. Agreed, its definitely not as aggressive as the Dodge. Watch your boost gauge...you'll see it working.
Old 01-18-2018, 09:54 PM
oudive's Avatar
oudive
oudive is offline
oudive is starting off with a positive reputation.
I run mine when I can. I ran mine all the time when I had my Ram and never questioned whether it was working or not since it was aggressive and could hear it. I am still getting use to my Ford Exhaust Brake. Until I had read about watching the boost gauge, I was concerned it was not working. When over 1500 rpm's, it becomes more noticeable, still different though.
Old 01-18-2018, 10:19 PM
diamondbackmike2004's Avatar
diamondbackmike2004
diamondbackmike2004 is offline
diamondbackmike2004 is starting off with a positive reputation.
I notice mine.....then again this if my first diesel, honestly my first truck larger than a ranger. so i notice a lot of things that i think get taken for granted but are new and exciting for me.
Old 01-19-2018, 08:02 AM
ncsuperduty's Avatar
ncsuperduty
ncsuperduty is offline
ncsuperduty is starting off with a positive reputation.
i use mine all the time. wish there was a way to have it on all the time, and turn off when not needed. but haven't figured that one out yet.
Old 01-19-2018, 08:11 AM
K A M
K A M is offline
K A M is starting off with a positive reputation.
Turn ignition to RUN (DO NOT START)
Press Exhaust Brake button
Press OK on steering wheel
Turn truck off
This will turn the exhaust brake on when starting. Some say that it will only do it so many times on start up then you have to repeat. Don't know how many times it will hold it or will it stay on until you turn it back off.
Old 01-19-2018, 08:13 AM
ncsuperduty
Turn truck off
tried that. didn't work. i have a push button style, not sure if that makes a difference.
Old 01-19-2018, 08:15 AM
K A M
K A M is offline
Did you try not putting your foot on brake and hit start button?
Old 01-19-2018, 08:22 AM
ncsuperduty
yeah, essentially turning truck on without starting it.
here was my sequence. push button (no brake), wait til everything is turned on, turn on exhaust brake, press ok, push button to turn off truck.
i will certainly try it again though.
Old 01-19-2018, 08:45 PM
Horsehaulin8
Horsehaulin8 is offline
Horsehaulin8 is starting off with a positive reputation.
Can you use the exhaust brake and tow/ haul simultaneously? I have yet to use the exhaust brake, but after reading tee threads, I'm missing out when towing.
Old 01-19-2018, 09:05 PM
bhbdvm's Avatar
bhbdvm
bhbdvm is offline
bhbdvm is starting off with a positive reputation.
When y’all say, “all the time”, are you talking about just when towing or literally ALL THE TIME?
Old 01-19-2018, 09:15 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
Yes, I use it all the time, yes, you can add tow/haul, whenever you want, don't have to be towing. You can also use manual mode on the transmission or delete gears and force downshifts within the ability to increase the revs. The more revs, the more hold back, the more load, the more effective the engine brake is. In fact the hold back at low revs isn't very noticeable, but once you increase them it is.
Old 01-20-2018, 10:42 AM
diblasi's Avatar
diblasi
diblasi is offline
diblasi is starting off with a positive reputation.
I just tried with the auto exhaust brake on my push start worked like a charm. Thanks
Quick Reply: Exhaust Brake
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
