1993 Ford F-250 drive shaft length - Ford Truck Enthusiasts Forums
Old 01-18-2018, 04:43 PM
Kane88 Kane88 is offline
Kane88 is starting off with a positive reputation.
I am doing a body swap with my truck and taking the 2wd body and putting it onto a 4x4 chassis. The only thing that I am missing to complete the build is a rear drive shaft. It is a regular cab long box 4x4 5 speed with a zf5 transmission and 7.3 idi motor. What is the length of driveshaft that I will need? I possibly found one but need to know the length weld to weld on the drive shaft thanks.
Old 01-19-2018, 05:24 AM
hturner12's Avatar
hturner12 hturner12 is offline
hturner12 is gaining momentum as a positive member of FTE.hturner12 is gaining momentum as a positive member of FTE.
Go to a junkyard and see if you can find one.
Forward Drive Shaft Length Jwainwright1998 1997 - 2003 F150 1 11-23-2017 09:35 AM
Drive shaft length big ole ford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-03-2017 09:28 AM
Front Shock Travel length? Metal twister 1999 - 2003 7.3L Power Stroke Diesel 5 02-05-2017 01:11 PM
Drive shaft concern gas to diesel swap Mhintlian 1987 - 1996 F150 & Larger F-Series Trucks 2 09-12-2016 11:30 AM
Front drive shaft lengths arkredneck 1999 - 2003 7.3L Power Stroke Diesel 2 02-19-2016 04:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
