Good old hutch mod...
#31
Uh huh.. anyways I searched all the parts and came up with a total of $130 or so.. ps 120 filter $55, pipe to hose adapters (x2) $20-$30, fuel hose 5/16 and 3/8 $10-$15 clamps $5, 5/16 and 3/8 ags poly armour brake tube from auto zone $15,.. did I miss any parts? Also you think the brake tube will work??
#33
look at Sous parts list on the link above and you can get everything from Amazon but the filter. Think I paid $56 for my racor
#34
I just ordered everything for the hutch mod yesterday. Mine was closer to $200, but I also bought new filler and vent hoses. Figured while I was in there...
It appears that Sous’ Racor source (TDS Warehouse) is no longer in business. I bought my PS120 from Racor PS120-02 FUEL FILTER ASSY. PRE-SCREEN for $56.95 plus about $10 shipping to AL.
#35
Save the money on the 5/16 stuff. Take the return hose that's connected to the scren filters and cut it at the bend, then turn it 90*. Air travels up anyhow, so it won't get pulled into the 3/8 tube, which is 5" below the return 😉...hobby store will have an aluminum tube of 3/8 size, then just get a union...heck, I'm not even running the pickup foot. Measure correctly and its not needed. Any debris will be caught in the racor.
#37
https://www.ebay.com/i/301315096603?...D1420124585908 Would something like this work oryou think it’s kinda chincy??
#38
#39
I encourage you to use 5/16 hose between the filter and the fuel pump. (The SAE equivalent to the metric, correct size.)
My Hutch has been in place since 2010.
I use Wix 33972 filter now. It is 2x as large as the filter pictured.
All connections are double clamped now.
Eliminated foot.
Eliminated foot.
#40
Don't get me wrong I like/use Kubota tractors, but that filter looks very cheap/thin plastic bowl compared to the Racor. You'll definatly want to put a bash plate around it if you go that route.
When you do drop the tank you'll be surprised at the amount of rocks and plastic bags between the tank and frame. I know I was considering it's in front of the rear tires, and how far it is from the front tires that have mud flaps as well. And I don't mean pebbles, I'm talking golf ball sized rocks. It looked like i took my truck off roading in reverse thru a gravel pit.
#41
For those looking for a Racor PS-120 remember there are 2 models, the -01 and the -02. Difference is the Thread sizes for the fittings
https://www.parker.com/literature/Ra...ter_-_7600.pdf
#43
jsludlum2
67
06-05-2021 08:38 AM
jsludlum2
1999 to 2016 Super Duty
01-28-2019 06:09 PM
bkuuz1
08-27-2012 07:34 AM
