Higher then normal vgt% & boost
This is running flat ground no wind at 60mph high boost and vgt and mileage is bad. Usually boost is more like 2 psi. But then the other day it seemed to go back to normal running 2 psi and in the mid to lower 40s on the vgt%. Seems like when it goes to 5th gear torque converter locked is when the vgt goes up. Any ideas what's causing this
7.3stroker2
09-14-2016 01:37 PM
